I'm planning my van conversion (do not yet have a van) and I've read a lot about the difficulty of seeing oncoming traffic from the passenger side when there isn't a window in the passenger slider. I did a search on the forum and found a few mentions of the issue, but I was hoping to get more of a deep dive into after market window placement to possibly reduce/eliminate this blind spot.
I would prefer not to have any big fixed factory windows in my conversion if I can help it (I'm buying used, so we'll see what's available once I'm purchase ready), which includes back door windows and slider. I would prefer instead to install my own windows, likely from Motion Windows, exactly where I want/need them to fit my layout (...which doesn't exist yet, but anyway...). My gut tells me I do not want a window at all on my slider for security and privacy reasons. That said, I also do not want blind spots, however small, if I can otherwise avoid it. I am familiar with using side mirrors only when using trucks to pull a trailers, but I've always had the ability to also do shoulder checks, and trucks also have great visibility imo. I love my shoulder checks, y'all. There have been MANY times I've avoided chaos and/or destruction because of a well timed shoulder check. You might be different, but I would hate to lose that "security blanket."
So the question is: if I want to place the smallest window possible (such as a custom 18" long half slider or t-slider from MW) is there a specific place I can put this smallish window to cover the "worst" of the blind spot, or would I need a larger window for it to be worth it? I don't want to order a window I won't end up using, and I also need to start making some decisions prior getting the van since I will be on a 3 month build crunch (and windows have lead times). (not sure if it helps, but I'm 5'7". I plan to put a swivel on the passenger seat but not the driver seat)
From what I've read, there are ways to perfectly adjust the side mirrors to cover this issue, but as someone who learned to drive in LA, I also know that the "objects in the mirror are closer than they appear" can result in occasional misjudgement, and all it takes is one occasion... so I prefer having my own two eyes making the judgement, rather than than having to mentally translate distance/speed through the distortion (however slight) of the mirrors.
Thank you all in advance for sharing your experience/opinions/advice
