Hi @MsNomer, how is your Velit furnace install going? I'm about to start shopping for a gas heater and would love to get a review. Thanks.
Sent from my SM-G781V using Tapatalk
In this case to me the accuracy is secondary; it's really the repeatability that's important. If you take a reading over time under the same conditions (distance, etc) then if you see wildly different numbers it should indicate something is starting to go wrong; for instance it may mean that the intake or exhaust are getting partially clogged.Your link didn’t work.
How would one judge the accuracy of these meters? At least with a thermometer you have some sense of whether it’s within the ball park.
MsNomer, you have the best test, the poo test.I rolled a paper towel up tight and swabbed the interior of the exhaust pipe as far as I could reach. It came out clean. This is after probably 100 hours of running on the lowest setting, admittedly at low altitude because that’s where we are in winter.
Yup 👍MsNomer, you have the best test, the poo test.
And you get me thinking, not always a bad idea.
How about Ethanol Residue? I find it in the float bowls and fuel supply orifices of the gasoline powered garden equipment, 2 and 4 stroke.
Just bought a new chain saw, the guy told me to use non-ethanol fuel, said I would save a lot of trouble.
Webasto and Eberspacher both state officially that their heaters are compatible with E10. Intrinsically there is little to "gum up" provided that you run the heater monthly as per the manual. The biggest risk is to elastomer or plastic parts like hoses and such.Yup 👍
I started up my Honda power-washer after it sat for 2 years 😳. I thought it would be a bear to start, but once hooked up to the water & the choke on it fired up 2nd pull.
I have never run Ethanol gasoline thru it. I have many gasoline engines that I run higher grade fuel thru them in order to eliminate the Ethanol issue. Listen to those small engine repair guys & motorcycle mechanics, they fix that stuff.
I wonder how the “green audits” take into account all of the added carbon footprint for repairing gasoline engines that are screwed up with ethanol gasoline. Including buying new products, or the industry required to repair such small engines.
I noticed at my closest gas station, the three grades of gasoline that they sell now might have 10% ethanol in all of them 😡.
AFAIK, the Co-op's premium grade is still ethanol free. You should certainly run that in old engines that were built before they began adding ethanol to gas. Modern cars and chainsaws (etc) are designed for it. Check your owners manual. My Stihl chainsaw can take up to 10%. As for parking heaters, I agree with @Pierre O. Not something to worry about.I noticed at my closest gas station, the three grades of gasoline that they sell now might have 10% ethanol in all of them 😡.
Coincidentally it was a CO-OP & all 3 grades they have all stated on the pumps could have 10% Ethanol.AFAIK, the Co-op's premium grade is still ethanol free. You should certainly run that in old engines that were built before they began adding ethanol to gas. Modern cars and chainsaws (etc) are designed for it. Check your owners manual. My Stihl chainsaw can take up to 10%. As for parking heaters, I agree with @Pierre O. Not something to worry about.
Normally it is carburated engines, especially engines that are used infrequently, that are most problematic. A gasoline heater doesn't have a carburator or really any place that the fuel can accumulate and separate. If you don't use a fuel filter (I don't) all the fuel gets recycled in less than 1 minute. The fuel pickup is also away from the bottom of the tank.Coincidentally it was a CO-OP & all 3 grades they have all stated on the pumps could have 10% Ethanol.
This was new to me 😳. As before I recall it was 10% / 5% / Zero ethanol.
Yup, my commercial chainsaw “Husky” IIRC I bought in 2016. There is a difference between allowances in an owners manual possibly mandated by Govt, & “Best Practices” verbally provided @ the repair shop.
My life experience seems similar to @RobPromaster ,,, I have no problem running it and in my Promaster, but not the in my motobikes or gen sets, or other small engines.
I’m going to trust the “repair shop mechanics”.
Sounds like it is no issue with these gasoline heaters 👍 ,,, I would not know.
New to me, too! Apparently, I haven't been paying attention at the pump!Coincidentally it was a CO-OP & all 3 grades they have all stated on the pumps could have 10% Ethanol.
This was new to me 😳. As before I recall it was 10% / 5% / Zero ethanol ( now 10% / 10% / 10% ).
Can you post a few photos of your install?Well managed to remove my diesel heater and install my new Velit Heater.
I have my heater mounted in the middle of my van under a bank of drawers, I use a splitter to direct the heat forward and back from that point. This is the exact location I had my diesel heater mounted.Can you post a few photos of your install?
MsNomer,I rolled a paper towel up tight and swabbed the interior of the exhaust pipe as far as I could reach. It came out clean. This is after probably 100 hours of running on the lowest setting, admittedly at low altitude because that’s where we are in winter.
Thanks, I found a photo in one of your previous posts showing where you drilled in the sending unit.I believe the kit they are shipping now includes a standpipe suitable for our tank. Leave the original alone and install the new one nearby. The fuel sending unit comes out for this.
I'm follow this discussion with interest. I'm also wondering if Velit's supplied standpipe is the "right" length for a Promaster. I remember reading a Webasto/Espar(?) manual that said to trim theirs to a specified distance above the bottom of your particular tank so that there would always be some fuel reserved for the engine.I believe the kit they are shipping now includes a standpipe suitable for our tank. Leave the original alone and install the new one nearby. The fuel sending unit comes out for this.
I just looked online for information about pulling the sending unit. I didn’t find anything. What did that look like and were you able to do it without dropping the fuel tank?It’s assumed that you will trim the tube to appropriate length. It’s a generic standpipe that could fit many vehicles.
