Hi @MsNomer, how is your Velit furnace install going? I'm about to start shopping for a gas heater and would love to get a review. Thanks.
Sent from my SM-G781V using Tapatalk
I won’t go that far, but he is purging his material & hiding his profile;It looks to me like Showtime is a Troll, and by continuing a discussion with him, we are just taking the bait..
An internet troll, or online bully, deliberately tries to offend, cause trouble or directly attack people by posting derogatory comments on Facebook posts, blogs, under YouTube videos, on forums and other social media, such as Twitter and Instagram.
Hi RV,Yup 👍
On The Forum ,,, This happens all the time. I post something 100% related @ the same time other members do;
Many DIYers do not understand the difference between a Propane “Furnace / Heater” by your definition & the liquid fueled gasoline / diesel “Heaters” as you define it.
I just posted the exact same thing above in post #78.
Depending upon the type of thermostat, the Propex or Suburban comes with, the operation and accuracy is within a couple of degrees F.
I have no Suburban experience, but in communication with @Dennis CampMaker & @GaryBIS I have concluded the Propex is very accurate with the DigiStat & depending on the Suburban thermostat it too can ve pretty accurate.
Thanks for your clarification.
Yup @GaryBIS ,,, Thanks for that 👍.Hi RV,
Our Suburban propane furnace has been very reliable at all altitudes.
The thermostat cycles it off and on and controls the temperature within a couple degrees.
The installation is straightforward - in part because they really don't leave you any options.
I've never had to clean it or adjust it over something like 8 years. It has never failed to start and run on the first try.
It is built in the same way as my home propane furnace. It has the same sort of burner, igniter, blower and heat exchanger as my home furnace. And, it has the same safety features (flame detector etc.).
Honestly if there were a proven gasoline furnace, I might well switch to it and go to an induction cooktop and regain the space my propane tank takes up. Maybe the Velit is it, but since I have a solution that works well now, I'm going to wait and see.
Hi RV,Yup @GaryBIS ,,, Thanks for that 👍.
My 2018 Propex HS 2800 has been living & working up in the Yukon since 2021 after its time with us.
Can you define the Altitudes you have been at with your Suburban ( true or density - whatever you remember experiencing ). I think @MsNomer is an extreme use high altitude use compared to most. I believe the highest asphalt road in Canada is 7500’.
Suburban is also on my radar as an option to the Propex ,,, thru wall install has its advantages 👍.
Yes - the suburban/atwood (now Dometic) -type units have been built forever and ship with pretty much any RV so it's many millions of units overall. They've definitely proved to be reliable and safe and as you say, the installation is quite difficult to "mess up". They tend to be mostly installed at the factory by RV manufacturers anyway.Hi RV,
In our Layout, if it could fit here, the Suburban would work (same spot as the shore plug - in front of the bed gableHi RV,
We have used it probably a dozen times at Island Lake CG on the Beartooth Highway.
The elevation of 9518 ft.
I think that may be our highest, but not certain - some of the campgrounds in the Rockies are pretty high.
The things that could be a bit better on the Suburban...
- The installation allows about zero flexibility - it pretty much has to go on the floor with the exhaust going directly out the sidewall. Of course, this may contribute to its trouble free operation
- It could be a little quieter.
Hmmmmmm 🤔Ok this is getting creepy now.
At least on the Transit and Sprinter forums there isnt the old boys club aspect of this place. This has turned into a circle jerk of the same 4 or 5 retired guys. Notice how terrible engagement has been for the past few years? How nobody posts anymore? That ain't because of me the "troll".
Hilarious to watch these dudes trip over themselves to defend the honor of a random Alibaba heater importer that sold them faulty units.
Instead of using the analog thermostat that came with the Suburban heater, I started using this digital thermostat which allowed me to set a specific temperature. It had a very small range from high and low of about 2 degrees. https://www.amazon.com/gp/product/B00204WWGE/?th=1I have no Suburban experience, but in communication with @Dennis CampMaker & @GaryBIS I have concluded the Propex is very accurate with the DigiStat & depending on the Suburban thermostat it too can ve pretty accurate.
I would like to replace my mechanical Atwood thermostat. Can you explain your above statement please?...................It had a very small range from high and low of about 2 degrees. https://www.amazon.com/gp/product/B00204WWGE/?th=1
Mostly Eberspacher heaters, primitive versions of today's models but with the same operating principle.Had a flashback, what were the VW Bug gasoline heaters, anyone remember? They were mounted in the front under the hood.
If you haven't installed it yet, I would ask their tech support if the pump and ECU that you have are the "good " versions. I'm having to replace both after already installing the unit.Well MsNomer helped me make the decision on the VeLit, it is sitting in my garage waiting to be installed.
I currently have a diesel heater installed with a modified jerry can as the fuel cell. it works very well but still a paid to buy a separate fuel.
Hi,Had a flashback, what were the VW Bug gasoline heaters, anyone remember? They were mounted in the front under the hood.
I still do not have a heater installed. Have been waiting for the Velit drama to settle down. Considered mounting a diesel tank under the body and using the Def mount under the gas fill cap. Also considered mounting a diesel tank like one of those all in one units, but the last one leaked and the diesel smell is still renting space in my head.
In summary, the unvented propane turned the interior into a steam bath, maybe a vented propane heater would work. Diesel smells worse than the poo the dog rolled in. And Showtime had a point, though the drama was a bit overacted.
MsNomer, watching you![]()
Yep, our '71 Westy had one. Broken when we bought it, never fixed it.Had a flashback, what were the VW Bug gasoline heaters, anyone remember? They were mounted in the front under the hood.
