Hi @MsNomer, how is your Velit furnace install going? I'm about to start shopping for a gas heater and would love to get a review. Thanks.
Sent from my SM-G781V using Tapatalk
Really gross to see a few people here STILL push this cheap junk product just because the owner has talked to them and pretended to be their buddy. Shows how far social marketing can get you. its junk. And you STILL have MsNomer and the other guy pushing these hard.I too have a Velit that has had issues. I installed it this last summer and test fired it and it seemed to work as it should. Then this Fall as the weather cooled we started to use heat, the heater worked fine but we really only used it 6 or 8 times. Then on our coldest night (18F) and highest altitude (5100ft) the heater wouldn't start and showed an error code of 07. Several tries to start had the same results.
We came home after that trip and the heater would start and run at home which is at 3100ft. I contacted support and they said I needed a new pump which the promptly shipped. I am not looking forward to spilling gasoline when I change out the pump, but I will be soon because we are leaving on a trip Tuesday. Hopefully the pump takes care of the issue.
Velit support might be good, but I would prefer a product that requires no support.
lol. Uhhh....you mean like their previous BS fake claims of the original ECU working perfectly at 16k feet? Im sure hes 100% truthful this time!My ECU was replaced for the intermittent E05. My understanding from Will is that the first batches of ECU and pumps had flaws that weren’t detected until the units failed in the wild. Will confirms that the replacement ECU I was sent in August is the one tested in Colorado, so they must have dialed in the settings pretty darned well.
There is significant evidence that the Velit gas heater does work quite well at all elevations and is available for a reasonable price. Every new business has a few challenges at the beginning.lol. Uhhh....you mean like their previous BS fake claims of the original ECU working perfectly at 16k feet? Im sure hes 100% truthful this time!![]()
No....there actually isn't. Once you get outside of this forum and read user experiences its been basically a piece of junk for most real people. The only "evidence" of it working at high elevation is yet another made up BS graphic from Velit and the word of influencers like MsNomer.There is significant evidence that the Velit gas heater does work quite well at all elevations and is available for a reasonable price. Every new business has a few challenges at the beginning.
Well @Showtime I heed your warning, as I do not have a need, so I have the luxury of waiting for the Empirical Data 😁. In my case, this data would be sourced after years of use by multiple users @ multiple environments, with honest reporting. Other than than ,,, place your bets & puts downs your moneys.No....there actually isn't. Once you get outside of this forum and read user experiences its been basically a piece of junk for most real people. The only "evidence" of it working at high elevation is yet another made up BS graphic from Velit and the word of influencers like MsNomer.
Its just an Alibaba piece of crap with their name printed on it. Just like their 12v AC units.
I can't attest for the Velit but many/most problems with these units (independent of brand) are user caused, often through improper installation or by using outside of the altitude spec.Well @Showtime I heed your warning, as I do not have a need, so I have the luxury of waiting for the Empirical Data 😁.
I believe any of these RV heater furnaces can be problematic ,,, All of Them !!
I ran the gambit with my last Propex. I even had the dealer review my install ( the dealer is near Duncan BC ). During the install review, he could not find anything wrong with the install, but said it is not the regulator, and it’s probably something that got sucked in the intake as these heaters are very sensitive. I then remove the heater and heat bench tested it. There was nothing wrong with the install or the heater, and after a road trip to Utah, during a combustion error and non-firing start up, I decided to field alter the propane, final regulation, pressure. That was the fix, so far.I can't attest for the Velit but many/most problems with these units (independent of brand) are user caused, often through improper installation or by using outside of the altitude spec.
Inherently, due to their design, they are very sensitive to installation of the combustion air intake and exhaust, and also the fuel line. Many people disregard the instructions (line length, orientation, etc.) and many run into problems.
Ours (a General Components Bison) runs very well so far. We're just back from a 4-day trip where it ran for about 40 hours, and burned about 10 liters. It is really great to tap into the fuel tank when you have extensive usage. But you need to remember they are not "furnaces"; they are "heaters".
This is just plain WRONG. Several videos have shown that while the external casing and heat exchanger resemble Espar (expired patents), the combustion chamber itself has never been seen before.Its just an Alibaba piece of crap with their name printed on it.
If you check the definition of “influencer,” it is clear that I am not one. If I were, I would be paid and I would not be open about the problems we have had. I do admire entrepreneurs who defy naysayers. Without them, we’d still be riding in buggies.influencers like MsNomer.
Ah yes...the other guy who Velit talked to and made feel special. Trusted source of info!Hey, @Showtime it is easy to be a critic without providing any evidence, alternatives or solutions. Then it's just noise.
I did a quick Google search and pretty much found only positive reviews. Can you post some links to the negative reviews of the Velit heater?
What exactly is your beef with Velit? It seems very personal.
So what do you recommend for a heater @Showtime ??Ah yes...the other guy who Velit talked to and made feel special. Trusted source of info!
No beef with Velit. Other than they just rebrand junk. And I hate seeing influencer wannabes steer people to junk.
Ah, yes, and yet you still fail to back up anything you claim with any evidence.Ah yes...the other guy who Velit talked to and made feel special. Trusted source of info!
You are on multiple forums like a salesman for this thing. Because Will made you feel special. While he took your money for a known junk product.This is just plain WRONG. Several videos have shown that while the external casing and heat exchanger resemble Espar (expired patents), the combustion chamber itself has never been seen before.
The bottom line is that there is no other unit on the market at any price that could meet our needs as well as the VeLit does. (Caveat below). We do not miss the Webasto it replaced. I don’t understand where Showtime’s negativity is coming from.
Caveat: The Bison/General heater claims to have the high-altitude capability we need. I became aware of it after we bought the VeLit, so did not consider it. I haven’t seen any high-altitude test results, but there should be some user experiences this winter.
I suppose by MY definition ,,, All these heaters are JUNK, because they ALL are problematic.
You dont have to look very far. Just read this thread. Theres two people who Velit made feel like special people and the rest have had bad experiences. Hell the main influencers here has changed parts like 3 times already and still wants to sing their praises. Now check out the Transit forums. MsNomer does an even more aggressive sales pitch over there.Ah, yes, and yet you still fail to back up anything you claim with any evidence.
Me thinks you are a competitor hiding behind that pseudonym just to trash other people's products.
Prove me wrong please post something useful rather than just diatribe.
What I meant is they are not really designed (at least not the liquid fuel heaters) for fine temperature regulation. Combustion is optimal when they are run at full power, and the cycling on/off takes several minutes (again for the fuel heaters) and considerable power. Many have a thermostatic mode but even then the range of usable power is only about 2:1 (max to min) so the effectiveness is limited.Can you clarify your statement; But you need to remember they are not "furnaces"; they are "heaters". As I do not know what you are getting at?
Well I went Propane, because after floundering around it seemed like the best type to give the least amount of problems.I think i already said earlier in the thread. Espar B2L AS3. If you want a cheaper option get a Bison. If you want a Velit just order a chinese heater directly off Alibaba yourself and save the middle man.
Very true. Just an old-fashion inspiration, especially on the hiking frontIf you check the definition of “influencer,” it is clear that I am not one.
Yup 👍What I meant is they are not really designed (at least not the liquid fuel heaters) for fine temperature regulation. Combustion is optimal when they are run at full power, and the cycling on/off takes several minutes (again for the fuel heaters) and considerable power. Many have a thermostatic mode but even then the range of usable power is only about 2:1 (max to min) so the effectiveness is limited.
To me a furnace is like a Suburban RV unit, which regulates by switching on/off like a home gas furnace does. Maybe the propex units are also like that, I have no experience with them.
