Question on using contact cement for gluing down Formic. possible problem with adhesion or maybe Silicone mats
2.1K views 34 replies 11 participants last post by  rumpus
#1 ·
Hi all,
I looked at the listings for Formica install on the forum but didn't see the question I have so here goes. We want to put in a couple of countertops and want them light and reasonably durable so we are leaning towards Formica applied over pine ply.
Formica gets applied with contact cement. When I contacted the Dap company that makes contact cement and also the Formica company they both did not recommend using Formica with contact glue for a van application
because the vibrations from the van would cause the glue to fail. DAP said once the glue dries it could handle the temperature variations but not the vibrations.
It looks like lots of people on the forum use Formica over wood ply so... what type of glue did you use and how is it holding up?
Also we just noticed another possible countertop covering...rolls of Silicone mats that you can lay over the entire counter and wonder if any one has used a food grade heat resistant silicone mats and if that would work? That takes us in a whole different direction. It looks like 3M Marine Fast Cure Adhesive Sealant #5200 which might be a possible adhesive. It is waterproof but comes in a caulking tube could be used for the Silicone mat material.
Any thoughts on how durable the contact cement is or if there is another suggested glue for Formica or has anyone used Silicone roll mats with this 3m Marine Adhesive Sealant #5200 or another glue?
Thanks for your input and help. Happy travels.
#2 ·
Ooo, following this thread because I haven't put a lick of thought into my own future van countertops yet, and I ought to start. Also looking forward to seeing what the forum's thoughts are on this 👍
#3 ·
I have used plastic laminate (Formica is one brand) on 3 previous campers with no problems. Put nearly 100k miles over 15 years on the last one. I always use the solvent based contact cement...nasty fumes, do it outdoors and/or wear a good mask.
#9 ·
As much as I dislike plastic counter tops, laminate is the most waterproof. Apply it over good Baltic Birch or marine ply and seal the hell out of edges and backside with epoxy or similar coating. Should last as long as the van.
I am skeptical of the 'vibration' deamination. Horse saddles are full of Barges Contact Cement. Never had a saddle fall apart or even think about delaminating.
#11 ·
As well as the edges if possible. Anything to not allow water to find a path to your substrate (rot/mold) will serve you well.
To add to your suggestion, the bottom and edges don't have to be the same high priced selection as your Pretty Showpiece. Actually, the thinner more flexible/less expensive laminate selections will protect just fine and can easily be formed to scribed profiles. A good marine brushable epoxy is quicker and less expensive than fooling with edge banding laminate. And just as effective.
#24 ·
This is what @MtBiker was describing:
Layers:
laminate
adhesive
ply
adhesive
laminate
When one surface of ply can absorb more moisture than the other, ply warps. With this construction, neither side of the ply can absorb moisture.
#29 ·
Yep. Ideally at the right moisture content.
Look at an open bunk of plywood at a supplier outside of the SW. The top sheet is usually twisted doesn't lay flat. The sheets directly below are usually flat. Rub your dry palm on the surface of the top sheet. Your palm feels dry. Rub your palm on the second sheet.??
Buy really good plywood from a custom cabinet maker focused supplier and ask one of their technical folks for advice. Seems hard to find in some parts of the country.
#32 ·
I used 3M 30NF contact adhesive to attach phenolic countertops (similar to Formica) in my own van, and it has held without fail for 5+ years. We also used contact adhesive for a couple of our early company builds, thought not strictly with Formica, but with other laminate products. The only time I've had an issue was when using the DAP Weldwood (the super toxic stuff) and I had a countertop release after being laminated. Maybe the Weldwood was old or a bad batch, but I certainly won't use it ever again, especially when 30NF works so well and is WAY less messy and toxic.
These days we do all our countertop lamination using epoxy instead of contact adhesive--I'm not willing to even take a chance on having a lamination release again. The epoxy is bomb-proof, no way that laminate is ever coming off! We're usually laminating with a product like Paperstone instead of Formica, but the application process would be almost the same. There's a little more prep involved when using epoxy, because the laminate needs to be held in place while the epoxy cures. You can do this with a sheet of plywood over the top and weights, even buckets of water. The less DIY-friendly way to apply counters with epoxy is to vacuum laminate it, which is how we do it now. The vacuum process yields a perfect, void-free bond, but there are extra materials, tools, and set-up required.
Here's the last counter we laminated, 1/8" Paperstone to 1/2" Baltic birch ply. These two pieces were a total of 1344sq.in. of material, and at -15psi, that's 20,000 lbs of clamping force!
#34 ·
Wow thanks for the detailed answer and sharing of info. What is the brand of Epoxy do you use? I don't think we have a way to vacuum seal it so given that what would be your first suggestion for us be epoxy or 3m30NF?
Love the color of the Paperstone which I had never heard of. I will look into it.
Could I ask you another question on sealing up the wooden potty so it is protected from any spills on the inside? I got a number of suggestions ranging from shower membrane, to epoxy, to just urethane to a product called rubberize it. Any thoughts on how you would finish this?
By the way lovely cabinet. Is it painted and has that worked well? I was recently toying with the idea of paining the inside rougher side of our cabinets with some mold proofing in the paint. We are using pine. How did you finish the cabinet? Lovely looking.
Thanks. Happy travels.
#35 ·
We use West Systems epoxy, which is sourced from our local marine supplier, but there are several good brands of epoxy out there. Honestly, as much as I like the epoxy method, if you're doing a small project or a one-off, I'd suggest the 30NF. It's easier to use, easier to clean-up, and bonds immediately when applied correctly--no extended set-up time. Just watch a couple of good Youtube vids about how to layout and apply laminate with contact adhesive using the "stick/spacer method". This will ensure proper alignment of your laminate, and help avoid headaches. And spend the $20 to get a J-roller as well.
Paperstone (or Richlite, similar product) are great, but also expensive, and not available at your local home store. We use a lot of 1/8" Paperstone that we buy in 5' x 12" sheets--and that's a very awkward sheet of goods, believe you me! I like to laminate to plywood for countertops so that we can use mechanical fasteners (i.e. screws) to attach the countertops to the cabinets. Also, the edge detail can be quite lovely.
That particular cabinet is painted with a Benjamin Moore product called Skuffex. It's a rather tough latex paint, applies nicely and is easy to touch-up down the road.
