Hi @MsNomer, how is your Velit furnace install going? I'm about to start shopping for a gas heater and would love to get a review. Thanks.
Sent from my SM-G781V using Tapatalk
Those are not the best clamps for the hose. They might work for now but you should use the correct size fuel injection line clamps.The Lowes small worm gear clamps solved that issue of having air in the fuel line and dripping fuel during startup. After clamping I tapped and flicked the bubbles out of the line going up to the heater. It's working great now.
Something like this?Those are not the best clamps for the hose. They might work for now but you should use the correct size fuel injection line clamps.
Same type; as @83Grumman mentionned these are sometimes called "fuel injection clamps"; but maybe these are too small. Often 10 mm ones are used such as these: Webasto Fuel Line Clamp 10mm 5 pack 5012000MP5. Similar ones should be in your velit kit.Something like this?
Getting my Velit today!
Nitro 4x4 1/4in Hose Clamp 10 Pack
Shop for Nitro 4x4 1/4in Hose Clamp 10 Pack with confidence at AutoZone.com. Parts are just part of what we do. Get yours online today and pick up in store.www.autozone.com
Those are probably too big. Their range is from just over 1/2" to 7/16", they are 1/4" wide.Something like this?
I don't see any evidence of oil under those clamps.Ok! I tightened the 2 clamps at the sending unit, and then the two clamps at the inlet for the fuel pump. I turned on the heater, and once the fuel pump kicked on there was no space or bubbles in the line, just solid fuel on the inlet and outlet end of the fuel line and then the heater fired up without issue. I’ll keep an eye on it though. Thank you for the help folks.
Eberspacher (and Webasto also if I recall) specify 1 to 2 Nm (9 to 18 in-lb). It's not a huge torque. It is important also that the clamp is not bent, otherwise it will not clamp evenly. Normally if you have the correct torque the "ears" should be close to touching one another but the clamp should not distort the rubber hose.This is a low, low pressure/vacuum application, they don't need to be overtightened.
If you don't distort, crimp, crush or squeeze the hose to compress the hose material it won't seal. The clamp needs to be tightened until it can't be rotated or slid on the tube and then a little bit more.the "ears" should be close to touching one another but the clamp should not distort the rubber hose.
Mine came with a muffler. I didn’t use it as it’s pretty quiet without it.I'm more interested in that muffler. Did it come with the kit?
Which heater? The Velit?From the manual:
"The performance may be compromised when using the auxiliary fuel port above 6000ft."
This may be an understatement.
VELIT 4000P User Manual page 11Which heater? The Velit?
Just received my Velit and it came with a muffler.I'm more interested in that muffler. Did it come with the kit?
Muffler did come with the kit.I'm more interested in that muffler. Did it come with the kit?
Hi @scribblersixVelit 4000
Also they removed the note in the instructions about the supplied standpipe only being compatible with metal fuel tanks. So I ordered the fuel tank sending unit removal tool in case I am able continue with this project.
Would have though gas would have fewer ignition problems vs diesel (which i used to have) since its more flammable and volatile
I doubt the standpipe significantly contributes to your issue. From the symptoms (severe carbon build up) there appears to be something defective in your unit causing a gross excess of fuel being burned."The performance may be compromised when using the auxiliary fuel port above 6000ft."
