41 - 60 of 70 Posts
I’m currently having the same problem. There was a hose that connected to a fitting a the driver side windshield that came loose. He said that was the cause of water in the tranny. He said the tranny looked fine, flushed it and said I should be fine. Then two weeks later when starting the sprindle said it was in R when it was in P and wouldn’t start. I took it to a different dealership and they said not only was there water in the tranny but the pan was very hard to remove and the gasket was so deteriorated that there were pieces in the tranny.
My PM is six years old but only has 57k miles. Is there anything else I need to know or say when trying to get them to honor the warranty?
This post has been updated to explain what happened.
Greetings to all,
2019 Promaster - 2.5 years old - 10K miles - Original Owner - Also have 100,000 Ext Warr
This has been the toughest challenge I have ever faced by an automotive company.
Was towed to the dealership because tranny would not go into gear. Though at the dealership it would again go into gear.
Upon inspection, the dealer said the transmission "had lots of water in it" and a warranty claim was originally denied by Chrysler saying that the water could only have come in externally. They are saying that this is my fault for the water incursion which could not be further from the truth unless driving in the rain is a problem. This van has been babied.
THEIR best initial explanation was that water came in through the transmission breather tube which is on top of the transmission, saying I was driving through, or in, floods. So far, research says that the transmission breather tube is at least 3 feet off the ground which, at 3 feet, would mean that water likely entered some doors if it was deep enough to enter the breather tube. This clearly did not happen and there was no residual evidence that the van had been in any deep water. Still the warranty had been denied.
Let's point out at this time that there is not a formal appeal process at Dodge/Stellantis. Or at least the dealer said there was not one, nor would the dealer give the phone number for warranty, nor the name or phone number for the Technical Advisor (the Dodge technical rep assigned to the dealer). Warranty primarily conducts business with dealer through a nameless, faceless web portal where the dealers submit a request and then it is either accepted or denied. Once denied your are pretty much screwed, so don't let the dealer submit until everyone is sure it will be accepted.
Knowing this I set out to find people to help. Through some exhaustive research, found the names, email addresses and in some cases the phone numbers of key players in the Chrysler/Dodge/Stellantis family in order to make a personal appeal for reconsideration. A reconsideration did happen. Let me explain.
One of the emails or phone calls prompted an executive to look into this issue further. I was assigned a very senior person in customer care whose job it is to deflect calls made to the executives. First, she listened to my story about which I was emphatic. She then rallied the troops ... warranty, the Technical Advisor, and the dealer. Within 48 hours and after some additional testing ordered by the Technical Advisor the problem was found. By the way, the Technical Advisor has the authority to override the decision of warranty, which in the end he did due to the results of the additional testing.
Part of the additional testing was getting a garden hose and running water over the van to see if rainwater could have been the cause. IT WAS. There were two issues, one issue compounding the other.
The center seam in the engine cowl (the plastic part which catches rainwater below the windshield) was separated or "had failed" and was directing water towards the transmission breather tube. So, all the water coming down the windshield on the passenger side of the van was not going down the drain, which is on the driver side of the van, but rather through the gap in the middle seam on the way to the main cowl drain.
The compounding problem was the main cowl drain on the driver side. This drain was clogged about half way down the "tube". There is not a screen which covers the drain opening so something went down the tube but did not exit the bottom. Other particles which then entered the drain opening were also blocked from exiting. Eventually this blocked the drain. With the drain blocked, any water now coming down the windshield on the driver side was accumulating in the engine cowl and then also exiting the gap in the middle seam. Except for testing the cowl drain with water there was no indication that the drain was blocked because nothing was blocking the drain opening. This is a design problem.
It might be wise for all of us to regularly check to see if our main cowl drains are passing water through to the ground.
Hope this helps others. Look for a thread that I will be starting about this and other issues which happen from engine cowl failures on our Promasters.
I am currently having the same problem. My PM is 6 years old and only has 57k miles. My PM jumped out of D to N at a busy intersection. The I went to said there was water in the tranny. There also was a loose drainage hose under the driver side windshield. They fixed the hose and inspected the tranny and said there was no damage. The flushed the system and said I would be fine. Two weeks later it would start. The sprindle said it was in N but it was in P. I took it to a different dealer and they said there was water in the tranny. They had a difficult time taking the pan off and said the gasket was just about gone. They want $7,100 to replace the tranny. They said my warranty expired a year ago. They directed me to the Chrysler assist number to ask for assistance. They did not mention a technical advisor.
Is there anything else I should know or do to get them to honor the warranty?
Posting this here as well, seems to apply
This is the vent on my 2018. If there is another vent I haven't seen it. I can't imagine how water could get in there. It sits on an elevated boss, water can not pool around it. Apparently there have been issues with wear of the bushing of the gear selector shaft. Its under the light brownish spot in the first picture.
Here is some reading material about 62LEs
Not much when searching for "water in 62LE problems issues". Only a couple references to the shaft bushing.
How long should it take for Customer Care to get back to you? This has been going on since April. I finally received an email from Customer Care providing a case number and a case manager, Jasmine on May 11. On May 18, I reached out since I had not heard from her. Still no response. This is very unimpressive.
Have you considered buying a used low mileage transmission(or a Re-man) and having and Indi swap it out? $7100 is crazy.
Also, FYI, the transmission mount has a recall out on it. Along with that, the bolts are not supposed to be re-used when replacing a tranny. See post #2 in this thread:
Greetings to all,
Greetings to all,
Hi there, I own a 2021 Ram Promaster with 11K miles and have recently discovered I have the window cowl issue many others do. Here's a video -
- I've been unable to get response from my dealer and wanted to see if you would share with me the name of the executives you reached out to that ultimately intervened and helped you get resolution. thank you!
They will likely not fix all the leaking points, maybe replace your 2 piece cowl with a flat one. Anyway here is a great guide if you want to really fix it yourself.
Promaster Leaking Cowl
Note to RamCares:........FFS, design an engine compartment that is not a Rain Forest !
I have had problems from the faulty cowling design and getting water dumped into the engine compartment. Living in a winter environment also means that once the water gets in the engine compartment it then also freezes there. The water in my van's engine compartment raised havoc with some my electronic connectors. There are 3 major design flaws with the cowling design.
1. The cowling is 2 pieces and is joined in the middle. This joint is not properly designed to funnel the water from the passenger side of the van to the driver side where the main drain is located. Whoever thought that you could place the passinger side of the cowling under the drivers side and expect the water to go up and over. Of course the water will go down and through the cowling. And if you rely on sealants there is so much expansion and contraction in the plastic cowling material at this point to break any seal set there over a short length of time.
2. The cowling is held to the windshield by double stick tape which it is hoped will stop the water coming down the windshield and direct the water into the cowling. This could work if installed properly as usually is done when the van's are built, but over time there are problems with this. The biggest being when a windshield is replaced. Most windshield installers do not realize that there is more to putting together a Promaster designed cowling than just resting it in place with the faulty clips that it came with. these installers do not know, or forget about, replacing the tape that is needed to create the cowling seal. Most vehicle cowling designs place the cowling resposible for draining the windshield water under the lower part of the windshield where this tape would not be required.
3. The drains that are on either side of the cowling are woefully inadequate and will clog with only a minimal amount of leaves or other debrie in the first year or two.
Greetings to all,
Hi, I am new to this forum. Just a couple of weeks ago my transmission started slipping and the dealership told me that it was due to water. Any chance you can share that contact info with me in regard to reversing your denial? I did have my windshield replaced back in January and my van started having issues shortly after that. The dealership discovered gaps in front of both driver and passenger side. The center seam was fully intact. They took a video that demonstrated water going directly through those gaps and onto the transmission. I went to my local safelite since it is impossible to get them on the phone. They denied warranty on the faulty work they did and then emailed me the link to this forum. Apparently safelite declines warranty just by using a google search. I have gone above the local safelite and straight to their warranty department and i just opened a claim with promaster. Any help or advise would be appreciated. This is my home and primary vehicle. I'm told it could be a year til I get a new transmission... the horror of this ordeal is ridiculous!
Oh, and my service advisor initially told me that due to the size of my vehicle simply driving in rain could have caused the water.. SERIOUSLY!!! I met with the mechanic after that and that is when we discovered the faulty cowl
The dealer used the same excuse for me and so I had the fluid tested and there was only trace amounts of water in it probably due to condensation vapor trapped in bubbles. The fluid foamed up due to them over filling during a standard transmission service. You can have it tested by Blackstone labs.
This addresses another potential source of water leakage that hasn't been discussed much. The OE nylon bushing on the shaft can deteriorate, crack, and let water in. This combined with a leaky cowl sounds more plausible than water entering through the intact vent. The shaft saver video doesn't show removal of the shaft from the transmission. Anyone know what that entails? I'm wondering about preemptive replacement.
41 - 60 of 70 Posts
