1 - 2 of 2 Posts
There is a TSB for Left Transmission Mount Bracket Fasteners. I was not able to open it so what it is I have know Idea it's dated 09-05-2019. Some folks have said they have had broken transmission mounts, so this may relate to that problem.
23-022-19 2019-09-05 2014-2020 VF Left Transmission Mount Bracket Fasteners
Discussion Starter #2
Here's the content of the TSB
NOTE: This bulletin applies to vehicles equipped with a 3.6L V6 24V VVT Engine (Sales Code
ERB) and a 6Speed
Automatic 62TE Transmission (Sales Code DG2).
DISCUSSION:
The fasteners used on the left transmission mount bracket are of single stage type and cannot be
reused. Once the fasteners are torqued, they must be replaced upon any removal. The torque of
the fasteners is of a higher torque than for a similar sized fastener. Refer to the detailed service
procedures available in DealerCONNECT/Service Library, for proper bracket torque and to check all
other mounting bracket torque specifications. Some fasteners have a torque value higher than
most bolts of that size.
CAUTION! Do not reuse fasteners. Reusing fasteners and not installing new fasteners
tightened to the proper torque specifications can lead to bracket bolt failure.
1 - 2 of 2 Posts
