21 - 40 of 76 Posts
Discussion starter · #22 ·
Wanted to bump this back up to the top, wondering if anyone has had any luck yet on OBD2 tech with anyone so you can monitor transmission temp and oil pressure on a gas engine Promaster? If so, which company has made it?
Thanks.
This post, not mine, was dated Oct '18, might work on the PM?, for those of you with ScanGauge.
I just got these codes from ScanGauge to program an X-Gauge into the ScanGauge so it reads the temperature in the transmission of the 62TE 6 Speed Transmissions found in the 2012 - 2019 Dodge Grand Caravans.
I thought I would post in this section for future reference for those searching the Internet for this information, as you need to know the temperature of the fluid in the pan for correct refilling procedure using a measuring dipstick like the one Dorman makes. Not everyone has access to a proper scan-tool to read this information and most cheap ones will not do it, but they might have a ScanGauge or have a friend that has one. Or might just want to watch the temperature as they are towing.
X-Gauge Programming codes:
TXD: 07E022B010
RXF: 046205B00610
RXD: 3010
MTH: 000100400000
  • Like
Reactions: keeponvaning
I realize you can't do this while driving, but a non contact lazer thermometer pointed at the trans pan will give you a good idea of the oil temp in the transmission. I do this when I use a dipstick to check its level.
I dont bother. Fully warm and idling in neutral on level ground, the spec is 2” on the stick. Set it there and forget about it.
I could be mistaken, but I have evidence that this particular trans is tolerant of being underfilled, but not tolerant of being overfilled, which is why the filling is such a proceedure. I have personally run our trans OUT of fluid (leaking) several times. It starts slipping, then just doesnt move. Add more and it worke fine again.
But overfilling it might put the fluid level up by the spining bits. This would froth the fluid and aerate it, and trying to drive on air bubbles would likely cause rapid wear. My guess is that this is why the factory is so anal about the level.
TXD: 07E022B010
RXF: 046205B00610
RXD: 3010
MTH: 000100400000
Linear Logic customer service me an email (November 2020) with info on this topic that I have pasted below AND it worked on the SG2 we just installed in our 2020 Promaster 3500 Travato:
"These XGauges worked for a 2017 customer, for engine oil temperature and transmission fluid temperature:
Engine Oil Temperature (°F)
TXD: 10F121E8
RXF: C32100000000
RXD: 3008
MTH: 00090005FFAD
NAM: OIL
Transmission Fluid Temp (°F)
TXD: 10F1229110
RXF: C46205913610
RXD: 3010
MTH: 000100400000
On your ScanGaugeII (with the vehicle running) select MORE> MORE> scroll to XGAUGE> EDIT. There should be a number on the top right of the screen. For each XGauge, you will need to select a different number (memory slot) that does not already have an XGauge saved under it. Once you select the number, press EDIT (bottom left) and you will be prompted to enter in different parts of the code, pressing OK> after each part. Each XGauge has five parts: the TXD, RXF, RXD, MTH, and NAM. Simply enter in the corresponding codes and after entering in the NAM press OK> and SAVE>. The XGauge should now be with your other gauges. These directions can be located on page 40 of the user manual."
NOTE: When I contacted UltraGauge with the same questions on Oil and Transmission they said, essentially, sorry we don't have a fix - thus my Scangauge 2 purchase.
Scan Guage 2 in 2019 ProMaster Gas. Have the following working.
Mode CANLF
TXD: 10F121E8
RXF: C32100000000
RXD: 3008
MTH: 00090005FFAD
TXD: 10F1229110
RXF: C46205913610
RXD: 3010
MTH: 000100400000
Fuel Level (30 sec updates)
TXD 07DF012F
RXF 0441052F0000
RXD 2808
MTH 006400FF0000
Name FLV
Full list of gauges shown, parked at idle about 5 mins
ATF = 41
OIL = 42
FLV = 74
HPR = 16.0
CPM = 9999
VLT = 14.4
IA = 40F
GPH = 0.91
IGN = 18
LOD = 21
LP = CLSD
MAP = 4.6
MPG = 0
MPH = 0
RPM = 1036
TPS = 12
WT = 150
AVG = ---
TFC = 0.42
this is a newer scan gauge so firmware is 4.5
support had suggested trying the other x gauges in cansf but only fuel level worked
as mode comes up as CANLF I plan to try some of those next
» X-Gauge Categories » CANLF
Tried the CANLF codes for Xgauges on the Scan Gauges 2 as they are what FIAT uses and found much more success. Here are the ones I know work from the CANLF list (manually added via xgauge and preprogrammed from factory. The pdf notes others tried and not working too.
Still no Oil Pressure. Support Rep gave one to try but it was from CANSF list and did not work.
Gauges of interest for some might be
Trans Fluid Temp
Oil Temp
Engine Water Temp (these vans run hot)
Catalyst Temps for Bank 1 and Bank 2
edit:2/23 corrected barometric pressure RXF to
044185330000
2019 Promaster 3.6L gasReadingGaugeTXDRXFRXDMTHName
Yes196Engine Oil Temperature (°F)10F121E8C32100000000300800090005FFADOIL
Yes149Transmission Fluid Temp (°F)10F1229110C462059136103010000100400000ATF
Yes37Ambient Air Temperature (F)33F10146044105460000280800090005FFD8AIR
Works ?137Barometric Pressure33F101330441853300002808006400450000PSI
Yes101Engine Run Time (Minutes)33F1011F0441051F000028100001003C0000ERT
Yes37Fuel Level33F1012F0441052F00002808006400FF0000FLV
Yes-1Short Term Fuel Trim Bank 133F10106044105060000280800C80100FF9CSF1
Yes-1Short Term Fuel Trim Bank 233F10108044105080000280800C80100FF9CSF2
Yes1Long Term Fuel Trim Bank 133F10107044105070000280800C80100FF9CLF1
Yes-4Long Term Fuel Trim Bank 233F10109044105090000280800C80100FF9CLF2
Yes64O2 Sensor Bank 1 - Sensor 133F101140441051400002808000100020000O11
Yes5O2 Sensor Bank 1 - Sensor 233F101150441051500002808000100020000O12
Yes70O2 Sensor Bank 2 - Sensor 133F101180441051800002808000100020000O21
Yes9O2 Sensor Bank 2 - Sensor 233F101190441051900002808000100020000O22
Yes1031Catalyst Temperature (Bank 1, Sensor 1)33F1013C0441053C0000281000090032FFD8CT1
Yes1034Catalyst Temperature (Bank 2, Sensor 1)33F1013D0441053D0000281000090032FFD8CT2
Yes74Fuel Level07DF012F0441052F00002808006400FF0000FLV
Yes14.2Horse Powerpre programmedHPR
Yes9999Cost per Milepre programmedCPM
Yes14.4Voltagepre programmedVLT
Yes40FIntake Airpre programmedIA
Yes0.91Gallons Per Hourpre programmedGPH
Yes18IGNpre programmedIGN
Yes21Loadpre programmedLOD
YesCLSDLoop Monitorpre programmedLP
Yes4.6Manifold Air Pressurepre programmedMAP
Yes0Miles Per Gallonpre programmedMPG
Yes1036RPMpre programmedRPM
Yes12Throttle Positionpre programmedTPS
Yes150Water Temppre programmedWT
Yes---AVGpre programmedAVG
Yes0.42Trip Fuel Costspre programmedTFC
Received these codes this week for the ProMaster camper and they work.
TXD: 10F122B010
RXF: 046205B00610
RXD: 3010
MTH: 000100400000
TXD: 10F1212D
RXF: 032100000000
RXD: 3008
MTH: 00090005FFAD
NAM: OIL
TXD: 10F122B010
RXF: 046205B00610
RXD: 3010
MTH: 000100400000
TXD: 10F1212D
RXF: 032100000000
RXD: 3008
MTH: 00090005FFAD
NAM: OIL
Thanks you for posting. Did they include the codes for oil pressure?
Has anyone had any luck finding a performance monitor yet so a person can monitor engine and transmission parameters from the vehicle's computer such as oil pressure, transmission temperature? I understand they're monitored but can't find a display monitor (not a programmer) to display the info. Several are sold as if they will, but contacting the mfg, such as Edge, they tell me they don't make one that works with the Promaster 3.6 gas.
I'm about to start searching mechanic's diagnostic tools, but would rather have one that can be dash or windshield mounted relatively permanently. I'm especially interested in monitoring transmission temperature, having had issues in the past with other vehicles. Of course, then, we tapped in a mechanical gauge. These days, one wants to tap the vehicle's computer via the OBD2.
Check youtube for a PM user with an ultra-guage, he seems to have his dialed right in.
ScanGauge X-gauge RAM Promaster Transmission Fluid Temperature
ScanGauge X-gauge RAM Promaster Engine Oil Temperature
I used @mloganusda's codes:
Transmission Fluid Temp (°F)​
TXD: 10F122B010​
RXF: 046205B00610​
RXD: 3010​
MTH: 000100400000​
Engine Oil Temperature (°F)​
TXD: 10F1212D​
RXF: 032100000000​
RXD: 3008​
MTH: 00090005FFAD​
NAM: OIL​
[/QUOTE]​
I can confirm that these codes worked on my 2019.
I'd really like to get the current gear that the transmission has automatically selected (not the handle position), but I haven't been able to find that code.
Thank you all for providing your experiences with the XGauge parameters for the PM. I have a 2019 3500 and glad to get Trans Temp monitored with our SGII when I head up steep hills in the West. Has anyone dialed in the oil life %. We head out on 2000-3000 mile trips and I would like to have a sense of the life before heading out. BTW, our oil change message came on at about 5000 miles, which seemed a bit early. Who knows what the algorithm figured out?
21 - 40 of 76 Posts
