Countertop? Ikea Veneer or solid wood butcher block from another place
3.8K views 31 replies 10 participants last post by  aaronmcd
#1 ·
Hello all,
Time to think of the countertop. We are looking for look like wood. Can we find butcher block at HD or Lowe's that are 1" instead of 1.5"? Or it's only order online? And what about Ikea, they praise their veneer countertop: are they less heavy, more solid, easy to work with... etc.
Best
#2 ·
I don't know about the US but in Canada Home Depot stocks 1" butcher block countertops.
I personally would avoid particleboard countertops (like the IKEA veneer countertops) in a van. For one I find they are much harder to work with if you want to rip them for instance but also I would be worried with how they hold over time vs temperature/humidity changes, and also how they will stay in place in case of accident. I attached our countertops with thick steel brackets and #14 screws. Plus I assume the particleboard countertops would be heavier than butcher block.
For our van I bough a 39x74 island countertop from with I made our galley countertop, table, the top of our bench/battery box, and I have leftovers for a drop down extension that I may never install and cutting boards.
#5 ·
You're absolutely right. My countertop weights approx. 16 kg. I feel it is adequately secured; the typical corner brackets used to attach a countertop in residential construction would definitely not be adequate. This is where at least solid wood has an advantage because it holds fasteners much better than particleboard. Actually depending on species butcherblock is not on the heavy end of the scale, it is less dense than particleboard or plywood.
I thought of hollowing out the bottom to remove some weight (and improve the sound? It works on guitars :p ) but did not get around to it yet.
#10 · (Edited)
I used ¾" ply too, but it looks like an 1 ½" because I put a second layer on the bottom that was mostly cut out like a collar. Our temporary counter was plywood with polyurethane on it and that was too much work for upkeep (my husband is not good at cleaning up water spots and shakes his hands dry). I wanted copper countertops but at the time the sheet copper would have been $400 and I baulked at that so I painted them to look like distressed copper and then epoxy coated it. Much easier to look after.
We still did major work securing it. We epoxied threaded inserts into it and used grade 8 bolts into house framing brackets. They are fixed to the cabinets and also the main pillars in the van.
#7 ·
My counter is 1/2” ply with a 1” lip to make it look like it's 1.5”, so effectively it is “hollowed out”. Life got a lot easier when I put laminate on top. Taking care of wood counter is too much work.
#8 ·
Yes, it is some work; "too much" is up to each of us to decide :) .
It really depends on what you're after. We did not want the full "natural wood" look in our van because we felt it was overwhelming in this small a space but we still wanted some natural wood, so we chose the ceiling, countertops, table and bed rails. The ceiling and bed rails have a polyurethane finish but for the rest 5 minutes every few months is how long it takes me to put some "butter" (mixture of mineral oil and beeswax) on the countertop and table and rub it in, primarily to prevent water from seeping in.
#9 ·
I got 1" acacia from home depot for my countertops. I wanted wood. I didn't care how much work it took. But it's not taken any work at all, except i cut on a cutting board because I don't want cut marks in the wood. I'd do the same with any countertop.
(it's stained with the recommended finish to be black/brown)
#12 ·
Look also at ¾” bamboo plywood, sometimes called “Plyboo”.
It’s hard and can take a beating, looks beautiful and doesn’t need to be laminated. We have bamboo cutting boards that are 20 yrs old and look new.
we used bamboo in our remote cabin. I did seal it with a hybrid oil/water based clear;
#15 ·
#22 ·
Update.
We went with the Acacia one. There probably is the recommendations for the finish: mineral oil or else, but if you have suggestions I am interested. Also, how do you attach it to the cabinets? Above the drawers it looks complicated. We still have to make one with the sink and one we will lift up ot have access to our chest fridge. So still a lot of work.
