Switching side mirrors
5K views 45 replies 11 participants last post by  Swoop
#1 ·
I found a discussion about this topic that was 6 years old. I'm wondering if there is any new information. I recently had my driver's side mirror destroyed by another on coming RV who was driving on the center line of a narrow road. I have the huge, long arm mirrors on my van. I got the mirror replaced, but now have PTSD about driving on narrow roads and meeting other big mirrors. I would like to switch out my big ears for the smaller version. Preferably with the power fold option. I've been talking to the dealership, but they seem skeptical that this is even an option. They are still looking into it. I'd be interested even if they weren't power folding. They are just too big the way they are. Any advice is appreciated.
#2 ·
I switched a little mirror a while back (complete unit from ebay), and it was really easy. I can't imagine that the mounting points for a 'big ear' mirror and the standard one would be any different.
Now, getting power fold would be a whole different matter. There's switching on the armrest that you'd probably want to junkyard. And I'm not sure what else is involved.
#3 ·
My passenger mirror looks just like your driver mirror! I hit a tree on a narrow road in the dark just 2 days ago. I already ordered a replacement. I looked at the smaller mirrors and there was an additional wiring harness that the big one doesn't have. So I ordered another big mirror.
I think switching for smaller ones would be a great thing. It would require a bit more effort figuring it out. I don't have the time for that now.
I bet @Baxsie could figure it out!
For now I can replace my big mirror with another big mirror. And I might replace the speakers while I'm at it. New mirror arrives Monday.
#4 ·
I'll let you know what I learn from the dealer. At this point, I'm willing to spend the money to switch. I hate worrying about this happening again. I was lucky on my trip that I was able to get it fixed within two days. But, next time it might not be that quick, and it really sucks spending hours trying to find a place to do it while on the road. I'm curious how often it happens. I bet it's a lot.
#6 ·
I probably would say the same about not using the folding option regularly if this had not happened to me. Now, I can't stop thinking about it. I did duct tape my broken mirror as best I could to get me 500 miles to a dealership that could get the part. I was in the middle of nowhere. It was not ideal.
#9 ·
I have a 2020 2500 that came with the factory long arm tow mirrors, and recently replaced them with the shorter version (power, heated, manual fold).
Replacement drivers side was an OEM from a wrecker, passenger side was Spieg from Amazon.
Straight forward change with no issues. Spieg mirror is not an exact match but very close, glass is a bit thinner and vibrated at highway speèd, solved by stuffing soft foam behind the glass.
Note to add power folding mirrors the switch panel also needs to be replaced, should be plug and play.
Visibility with the shorter mirrors is excellent, do not miss not having the power folding option.
#17 ·
I did some research to figure out which model numbers corresponded to which features, then found a couple of used mirrors on ebay. Enough time has passed that there are probably other options available now. I'll warn you that the replacement was a bit trickier and more time-consuming than I expected (removing panels, finding wires, etc.).
#20 ·
Replaced my mirror this morning. It was a 30 minute job. I had watched a YouTube video a week or so ago and was able to recall exactly what to do.
The 3 things that took the longest.
1. Finding my glasses
2. Prying up the window switch panel.
3. Routing the wire but mostly getting the connector connected again. Tight space to work in.
Daughter held mirror while I tightened the 4 mounting bolts. That is the only thing that makes it a 2 person job. We did this in our pajamas this morning. It started out as just gonna look at it. Then I thought I would just pop off panels. The next thing I knew it was finished.
#44 ·
The large mirrors can definitely be swapped for smaller ones (unless something has changed since my 2015 was made), but you need to be sure that the new mirrors have the same features (heat/folding/power adjust, etc.) AND that the wiring harnesses are the same. I spent a lot of time figuring that out for my mirrors. It is surprisingly complicated to access all of the necessary screws, harnesses, etc. to make the swap. I did it myself. I can see how it would easily cost a couple hundred dollars in dealership labor, if you pay to have it done. I have never regretted making the swap.
#45 ·
I'm not handy with that kind of stuff. The Dealership wanted $200 just to take mine apart to see if they could in fact replace. IF they could, it would be a LOT more. I got frustrated talking to parts "experts" who could not tell me what my wirering harness actually was after giving them my VIN number. I also called and spoke to Mopar. They were also clueless.
