It wasn't a prototype but had the latest firmware on it. No results, l.e. Nothing showed up which I reported back to him. I can only assume they are either still working on it or have given up on it.
This post, not mine, was dated Oct '18, might work on the PM?, for those of you with ScanGauge.
I just got these codes from ScanGauge to program an X-Gauge into the ScanGauge so it reads the temperature in the transmission of the 62TE 6 Speed Transmissions found in the 2012 - 2019 Dodge Grand Caravans.
I thought I would post in this section for future reference for those searching the Internet for this information, as you need to know the temperature of the fluid in the pan for correct refilling procedure using a measuring dipstick like the one Dorman makes. Not everyone has access to a proper scan-tool to read this information and most cheap ones will not do it, but they might have a ScanGauge or have a friend that has one. Or might just want to watch the temperature as they are towing.
X-Gauge Programming codes:
TXD: 07E022B010
RXF: 046205B00610
RXD: 3010
MTH: 000100400000
2019 Promaster 3.6L gas | Reading | Gauge | TXD | RXF | RXD | MTH | Name |
Yes | 196 | Engine Oil Temperature (°F) | 10F121E8 | C32100000000 | 3008 | 00090005FFAD | OIL |
Yes | 149 | Transmission Fluid Temp (°F) | 10F1229110 | C46205913610 | 3010 | 000100400000 | ATF |
Yes | 37 | Ambient Air Temperature (F) | 33F10146 | 044105460000 | 2808 | 00090005FFD8 | AIR |
Works ? | 137 | Barometric Pressure | 33F10133 | 044105330000 | 2808 | 006400450000 | PSI |
Yes | 101 | Engine Run Time (Minutes) | 33F1011F | 0441051F0000 | 2810 | 0001003C0000 | ERT |
Yes | 37 | Fuel Level | 33F1012F | 0441052F0000 | 2808 | 006400FF0000 | FLV |
Yes | -1 | Short Term Fuel Trim Bank 1 | 33F10106 | 044105060000 | 2808 | 00C80100FF9C | SF1 |
Yes | -1 | Short Term Fuel Trim Bank 2 | 33F10108 | 044105080000 | 2808 | 00C80100FF9C | SF2 |
Yes | 1 | Long Term Fuel Trim Bank 1 | 33F10107 | 044105070000 | 2808 | 00C80100FF9C | LF1 |
Yes | -4 | Long Term Fuel Trim Bank 2 | 33F10109 | 044105090000 | 2808 | 00C80100FF9C | LF2 |
Yes | 64 | O2 Sensor Bank 1 - Sensor 1 | 33F10114 | 044105140000 | 2808 | 000100020000 | O11 |
Yes | 5 | O2 Sensor Bank 1 - Sensor 2 | 33F10115 | 044105150000 | 2808 | 000100020000 | O12 |
Yes | 70 | O2 Sensor Bank 2 - Sensor 1 | 33F10118 | 044105180000 | 2808 | 000100020000 | O21 |
Yes | 9 | O2 Sensor Bank 2 - Sensor 2 | 33F10119 | 044105190000 | 2808 | 000100020000 | O22 |
Yes | 1031 | Catalyst Temperature (Bank 1, Sensor 1) | 33F1013C | 0441053C0000 | 2810 | 00090032FFD8 | CT1 |
Yes | 1034 | Catalyst Temperature (Bank 2, Sensor 1) | 33F1013D | 0441053D0000 | 2810 | 00090032FFD8 | CT2 |
Yes | 74 | Fuel Level | 07DF012F | 0441052F0000 | 2808 | 006400FF0000 | FLV |
Yes | 14.2 | Horse Power | pre programmed | HPR | |||
Yes | 9999 | Cost per Mile | pre programmed | CPM | |||
Yes | 14.4 | Voltage | pre programmed | VLT | |||
Yes | 40F | Intake Air | pre programmed | IA | |||
Yes | 0.91 | Gallons Per Hour | pre programmed | GPH | |||
Yes | 18 | IGN | pre programmed | IGN | |||
Yes | 21 | Load | pre programmed | LOD | |||
Yes | CLSD | Loop Monitor | pre programmed | LP | |||
Yes | 4.6 | Manifold Air Pressure | pre programmed | MAP | |||
Yes | 0 | Miles Per Gallon | pre programmed | MPG | |||
Yes | 1036 | RPM | pre programmed | RPM | |||
Yes | 12 | Throttle Position | pre programmed | TPS | |||
Yes | 150 | Water Temp | pre programmed | WT | |||
Yes | --- | AVG | pre programmed | AVG | |||
Yes | 0.42 | Trip Fuel Costs | pre programmed | TFC |
