I'd be tremendously grateful for anyone to share their knowledge with me. I have two main questions:
First, I built living space in the back of my Promaster to create a campervan. How do I determine if my 2019 Promaster 2500 can handle a Pure Sine Wave Inverter: 1800 watts 120 volts 15 amps connected to the vehicle's starter battery?
This inverter will be used while I'm driving to recharge a portable power station (Ecoflow Delta Pro). All of my lights and appliances are already wired to be plugged into the portable power station and it works perfectly. I just need an inverter to keep the power station recharged. I also have the option to use a larger inverter to get faster recharging time. I would like that but again, don't know if a larger inverter would be too big for my Promaster to handle; it would be 3000 watts, 240 volts, 12.5 amps. These spec's come straight from the manufacturer of the power station. The power station would simply plug into the inverter, using its built in, standard household appliance cord and plug; I currently recharge this power station by plugging it into any ordinary household electrical outlet.
My second question: I was led to believe that installing an inverter for this specific purpose is as simple as connecting one end of a cable to the Promaster battery's positive/negative contacts and the other end of the cable to the inverter's positive/negative contacts. Is this true, is it that simple? Is there something I need to do so that the battery can accommodate an extra set of contacts? Do I need to install any additional equipment? Must I specifically ground the inverter to my Promaster? Must I install a separate on/off switch to turn the inverter off when I'm not running the vehicle's engine, or do inverters already come with an on/off switch that's easily accessible each time I turn off the engine.
I'm widowed and on my own with this project, I have reached "senior" status,and on a limited income, and next month I need to move out of my rented home and into my Promaster campervan full time to live more affordably. So, I'm hoping to avoid the expense of hiring a mechanic to install this inverter. But, while I did the entire camper build myself using youtube videos and chat forums and reading articles, I don't know anything about vehicles, batteries, alternators or inverters, I don't know if I'd be over my head trying to do this myself.
I would be very, very grateful for any information or recommendations. My sincere thanks to this community!
