How to split water line for sink faucet / shower from same pump
436 views 6 replies 6 participants last post by  Dirtrider
#1 ·
I have decided to I want run some hose to the back of the van from the water pump so that I can have a little sprayer for shower / rinsing. Currently I only have a single faucet in the galley that is fed by a water pump and would like to use the same pump. I am wondering what is the best / most efficient way to split the line so that I can pump the water to the back? I have a simple system and have pretty good access to hoses coming off the pump. The methods I am considering are:
1. Use a 3-way Y splitter with shutoff valves where I would need to close / open the lines depending on which one I want to use - seems like a very minor pain with a little Y splitter that looks a little but fragile, but seems like it could work - something like this:
2. Use 2 sets of quick connects and just disconnect from one hose and connect to the other when I need it - this definitely seems like it would work and seems more sturdy but again a very minor pain to install the setup have to switch the lines back and forth and I'm sure it will leak a bit of water every time I switch back and forth - not a big deal but very slightly inconvenient
3. Just hook up a T or Y connector and split the line and don't worry about the shutoff valves because the pressurized water will just automatically divert to the proper source when using since I would never be using both at the same time - this is the most simple and convenient, but I'm concerned that it could potentially interfere with the pressure in the system since it is potentially "open" on one side
4. An even better solution that I haven't thought of yet
Thanks for any input!
#6 ·
Thanks so much for the helpful replies; what everyone is saying makes sense as I thought about it more - I suppose it won't hurt to have the shutoff valves there regardless for repair, etc. like aaronmcd mentioned
