Glad it helped. To clarify, my order was just the Sony unit and RR2 module…I had mine professionally installed (which still bothers me) and don’t know exactly what trim and wiring adapters they used. Also you only really need the RR module - the RR2 adds no additional capabilities that I’m aware of yet but it’s possible a firmware update in the future would allow you to control four custom relays from the head unit.
The only negative to this upgrade other than time and cost was that the factor backup camera looks terrible on such a large display. It’s kind of usable, but it’s blurry enough to make you less confident using it in tight situations. I finally upgraded the rear camera to the one below. Much better resolution! It’s a pretty distorted view right at the corners of the van because it’s wide angle, but you can still see more detail while watching those corners backing up. Getting one with less of a wide angle might be closer to the stock image.
I also like the fact that I could turn off the guide lines on the new camera and then adjust the guidelines that are part of the Sony system. Now that they’re set up, they show me exactly where the corners of the van are going despite the distortion at the bottom of the image. It looks weird in the image, but those lines are lined up exactly with the corners of the van.
I initially tried to match the wiring and connection to the factory camera but game up on that since the connector on my van is buried in wires above the rear doors and I couldn’t get to the at connector. So I ended up just leaving the stock camera loose in the rear housing (in case this didn’t work), mounting the new one by slightly enlarging the opening in the housing, and then running a new wire all the way to the head unit.
NATIKA Backup/Front/Side View...
https://www.amazon.com/dp/B083SF5VVN?ref=ppx_pop_mob_ap_share
