Hi
For the 12VDC I have mostly 12AWG & some 14AWG wire. Trying to think how to solderless connect to appliances e.g. puck-lights which have a 16 or smaller wire or other parallel connected devices e.g. the 12v sockets.
1. Should I step down to 14AWG (which kind of negates usefulness of wider gauge) and then use 3-way connector?
2. 3-way connect: This guy uses a two way butt connector. Is this acceptable? If so which size to use since he doubles the larger wire on one side? Advatgae here is the heat shrinking.
There are these no cutting t connectors. I read a review that their conductivity degrades over time.
Also I saw these Wago connectors used. It's only good up to 14AWG.
