21 - 29 of 29 Posts
From page 349 and 350 of your owners manual. The Horn is fuse location F10 and the heated mirror fuse is F35. Both are 15 amp (blue) fuses. Both of those locations are in the Power Distribution Center under the hood.
Hello,
Woke up this morning to only to get into my van and have no mirrors or radio. Pulled panel left of of dash only to find no labeling of any fuses locations.
Anyone have a fuse diagram or can tell me the fuse that runs the mirrors and Radio. I assume same fuse?
Cheers,
Tyler
I continue to have this problem, no radio no backup camera mirrors do not close or open, passenger side window switch do not work only from driver side switch. I CHECKED ALL FUSES UNDER THE HOOD. all good.
does any one have a solution???
Have you checked the fuses inside the van, to the left and lower than the steering column? The Power Window and Camera fuses are located there.
Internal fuse box looks like Fiat Ducato 2012.
Here a Fiat Ducato owner manual, from page 196 of the manual at section "ACCESSO AI FUSIBILI" there are the fuses diagrams.
http://www.giordanobenicchi.it/camper/PSA/Fiat ducato UeM x250 2012.pdf
For Google translate maybe better this page that is for a Fiat Ducato ambulance.
http://www.118gme.it/rubrica-tecnica-2/fiat-ducato/controllo-dei-fusibili/
Foldable mirrors should be F24 fuse that is in the engine bay fuse box (defrost is F30).
"Plancetta comandi ausiliaria, movimentazione e abbattimenti specchi (+chiave)"
F24 is labeled as Vacuum Pump in my manual and is only a 7.5 amp fuse. The Ducato manual says it would be a 15 amp fuse.
Has anyone figured out which fuse is for the power mirrors?
I went through all of the fuses inside and evetually discovered that F49 INT(PAM-CCS-RRM-ECM) is the fuse for the power mirrors. It was the one that was blown and immedialty blew again when I replaced it. I had just had the drivers side mirror replaced and a wire was picnhced and shorted. The shop replaced and rerouted that wire and my mirrors are fucntioning again.
21 - 29 of 29 Posts
