Thanks for looking at this.... it is definitely a learning curve. I am under the impression that CB (circuit breakers) can, if possible, be used in place of a fuse and separate on/off switch. Correct? It would simply things. Otherwise, another question, is whether a shunt is needed if a negative busbar is already in place? They come with the unit, so don't buy one, right? Then is the battery moniter sized for the battery capacity or the anticipated loads, as I was told the BMS was. Correct? The ' for feet is not doubled for circuit length, but I did it for checking the wire size and fuse... or think I did correctly, most are estimates. Let me know what you think. This will be a 24v system because K.I.S.S. didn't seem logical at the time, mostly because of the price of the 24v battery if you DIY it... so hopefully, I don't screw that up when it arrives, but the hard way seems to be my way of making my life difficult. Anyway, here's my current chart:
I think I did the solar wrong... seems 14 AWG might be ok with that as well... though most on sale seem to be 8 or 10, that must be the standard... I was looking at someone else's chart... but on review at BlueSea, the chart says 14 or 16. Odd. 10Awg would cover it at only around 10/20 round trip or +/- combined. Sorry about that. Consider that one corrected.
