The radio on my van was just replaced because my Blindspot detection wasn’t working. It’s now telling me that it is disabled. Does anyone know how to enable it?
Hi,I have the "Blind Spot Alert Diabled" issue on my 2022 Jayco Swift (2021 Promaster chassis) and would like to start a private conversation with @RamCares but apparently I have to make 5 posts before I can.
That's good to hear. My van is a year old now and I just stopped trying the BSM until a proper fix is found. Hasn't worked since day 1 and RAM will not do anything unless I bring my van (RV) to a dealer. Since both dealers in my area are horrible, I'd rather wait until I have a real warranty repair issue before having to go to a dealer (hopefully never). The part you mention is $100 - I may just buy it and see for myself if that helps.There is another thread on this subject so I'm responding twice.
The problem the techs have had is the fault doesn't throw a code, it simulates a trailer being plugged in momentarily. The BSM needs to be turned back on manually each time after towing. That is how it is designed so there is no reason to record "the incident".
Thus far, the closest thing to Ram acknowledging the situation is the mechanic's private forum where frustrated techs talk to each other. I mentioned earlier the best way to demonstrate the active problem is to drive with your lights turned ON while driving. When the fault triggers, drive right to the dealer. The fault will remain active until the engine or lights are turned OFF and they will be able to "see" the invisible trailer on their scan tool. Hopefully when enough of us have demonstrated the problem, it will become a tsb.
At the recommendation of the mechanic's forum, my dealer replaced the lighting control module #6837983AA and the BSM has not shut itself off since...
Thanks! I ordered the part and will see how it works for me. I dislike my local dealer so I was hoping someone would eventually post a fix that worked. Apparently this part had prior issues in older Promasters as well as it was recalled due to brake lights malfunctioning when a trailer was attached. Hopefully it works as well for me!!It has been two weeks since the lighting module was replaced and the BSM has not shut down. With daily temperatures in the 90's the van would never have gone this long without throwing the fault before.
I am calling this resolved. The difference is so substantial that if it were to reoccur, I would place blame on a defective replacement part.
I can always keep the old one and if the new one fails, I can reinstall before I return to dealer. Not sure how they would know I swapped it anyway unless it has a separate serial number.If you replace the lighting module (aka trailer tow module) yourself Ram will decline any further warranty coverage of this issue. They replaced our module, pronounced it tested and fixed, and the BSW failed before we got off the block the dealer is on.
To me, it seems obvious. The company that made the trailer tow module has a quality control issue so there are many bad ones. Many vehicles were made with bad ones. When the dealer ordered new ones to replace the bad ones, many of the replacements were bad, so the problem remained. Ram needs to develop a method to bench test these lighting modules before accepting them from the company and way before they come anywhere near actual vehicles. Will this cost money? Yes. But that's what happens when you let quality control slip all the way down to the customer level.
metalmagpie
So sorry to hear this! Could you send us your VIN so we can look into this further?My rig is in the shop now. They fixed the recall on the seatbelt last week but were unable to recreate the blind spot issue. Ten minutes after picking it up blind spot system shut down again. I took it right back and the tech plugged in a reader and it gave a strange brake light on high message.
Got a call earlier today that the blind spot system was enabled and they gave it a two minute test drive...
I live out of town I requested they take it for a longer drive.
The darn thing beeping at me for the 26th time in a row is a distraction. I can live without the blind spot alert but but as it is paid for it ought to work, no?
It kinda sucks to join a forum on a sour note and I apologize.
@RamCares Hi Hannah, I clicked on Ram Cares and do not see a way to 'start a conversation' or send a private message. We have a 2021 Zion Slumber Ram 3500 with a horrible, constantly resetting Blind Spot Monitoring problem. I wanted to send you or VIN and see whether you found a solution yet.Hello all! If anyone is experiencing similar vehicle performance concerns relating to your Blind Spot feature please send our team a private message with some additional details so we can investigate on your behalf. Let's work together here!
Hannah
Ram Cares
Glad to see I am not the only one with the blind spot issue, and also have no idea where the “start conversation “ button is located. Come on Ram Cares, help us all out.@RamCares Hi Hannah, I clicked on Ram Cares and do not see a way to 'start a conversation' or send a private message. We have a 2021 Zion Slumber Ram 3500 with a horrible, constantly resetting Blind Spot Monitoring problem. I wanted to send you or VIN and see whether you found a solution yet.
I am happy to start a conversation, Pony Express message, or send smoke signals. I cannot find a “start conversation” button.We understand the frustration you might be experiencing. To clarify, when we ask to send a direct message, we are collecting personal information so that we may begin a case to assist you. Each time we begin a case, we are documenting the issue with the vehicle, and assigning a case manager to you who can assist you in technical and part assistance, and advocate for you at the dealer. Our cases also help assist us in identifying wide spread issues with the vehicles that so that we can research and fix them. We hope this helps you understand a little bit better what we do!
Callie
Ram Cares
Hey there,I am happy to start a conversation, Pony Express message, or send smoke signals. I cannot find a “start conversation” button.
