I compiled these specs from various online sources. Please review and comment. I'd be happy to incorporate any additional info you have found.
Great! So if the alternator pulley itself is 2.04in (51.8mm) then the belt adds 0.21in. Subtracting that from your 6.125 makes the crank 5.915. Divide that by 2.04 = 1 : 2.9 ratio, which, as it turns out, is the same as the V8s after all. Apologies to @larry barello. I've amended the attach spec sheet.I don't have calipers so I made some cad calipers
180 amp alt
pulley + belt
6.125
2.250
ratio of 1 : 2.7
It would if the pulleys themselves were the same diameter, but since they are different, belt thickness is a different proportion of each pulley+belt diameter. If that weren't true, the adjusted diameters would yield the same ratio as the unadjusted diameters (2.7). Someone please correct me if I'm wrong.@SteveSS
I'm confused, I couldn't measure the actual metal surface of the pulleys, so I measured the outside diameter of the belts, wouldn't the ratio of 1 : 2.7 be the same as the metal pulley surface?
No, just the belt thickness relative to the diameters of the alternator and crank pulleys themselves. Since the pulley diameters are different, I think belt thickness has to be subtracted before calculating ratio. Our two ratio calculations, with and without belt thickness, seem to prove that. Do your diameter measurements include belt on both sides of each pulley? In other words, are your diameters equal to the metal pulley plus two belt thicknesses?Here the alternator, are you referring to the angle of the belt as it meets and departs the pulley (red)? Not sure how to word that![]()
