Hi all,
This is probably a silly question to most of you veterans on here, but I've had trouble finding the exact answer to my question while scouring the internet.
I have a 2000 watt Renogy Inverter. It has AC hardwire connections on it and 3 outlets. Rather than running extension cords from the outlets on the inverter to my kitchen area, I am thinking of installing a GFCI outlet (in an outdoor outlet box) in my kichen area and hardwiring that oulet directly to the AC connections on the inverter.
Is this safe to do? Or do I need to run the GFCI outlet to a specific GFCI breaker box first, which would then be wired into the inverter? I only need the one outlet, so my assumption is I'm alright and the reason for adding in a full breaker box is solely to be able to run multiple outlets out of it throughout the rig.
Hopefully that makes sense. Apologies if this has been discussed here.
Appreciate it!
Appreciate it!
