I was playing around with plus nuts and an Astro 1450 today to get an idea of how much force was needed to install them properly and came across something interesting that might help others. I haven’t seen this mentioned online anywhere yet, so forgive me if it’s old news or common knowledge now in terms of installing plus nuts or riv nuts.
When you drill a hole in sheet metal, it will usually leave a burr. If you don’t remove the burr, it will interfere with the installation of the plus nut/riv nut because they won’t be clamping down on a flat surface! They’ll clamp the burr on the backside, which is already weakened, and it easily allows the nut to spin with very little force when you later add your bolt.
For blind holes, you’ll need to use a round file or a pick-like tool to de-burr the hole. In the image, you can see that most of the holding power that prevents spinning comes from just the 2 ribs near the flange. The cross/plus part of the nut prevents pull out, but doesn’t do much (if anything) in regards to spinning.
I’m beginning to rethink the use of plus nuts and may switch over to riv nuts for their ease of removal and lower price. They also have more ribs.
