Hi all, I have lessons learned.
1. Both intakes should be drawing inside air. The HEAT mode needs incoming air warmer than about 41F. So if u are parking for the night and sucking in freezing air - you will not get heat. When you park the van after a days drive, the air in the van will be above the 41F mark and stay that way overnight when running in heat mode. (I only one hole in the van for EF waste air.)
2. If you are off grid, it kind of sucks that you have to purchase the EF battery. BUT...this battery has enough stored energy to keep me reasonably warmed up or cooled down overnight. During most days my 400watts of solar panels easily refill the EF battery during the day. I think it is a ten amp max via 12volt charging ports - not enough to run compressor, but enough to charge EF battery during daylight hours.
3. Connect the drain line to your van gray water tank. There is a toggle on your EF app for pumping/draining out water.
4. We have a tall closet who's door matches the width of the hall to our elevated two person bed (sideways mounted). So we can take advantage of each BTU coming out of EF by opening the closet door all the way so it becomes a closed bedroom door.
The EF conditioned air is sent to this closed "bedroom" to heat/cool this smaller space.
5. Twelve volt Booster Fans (like the ones used in computers). I did a lot of testing of the EF and found by helping the little squirrel cage fans inside the unit with booster fans for exhaust and conditioned air, you get better performance. I put a little rheostat on the conditioned air outlet so I can reduce noise for sleeping.
6. I did permanently mount my EF in the top shelf of a cabinet. No way was I going to have large hoses and power cords filling up my promaster living space!
For us, parking in loves or cracker barrel, the EF has made long road trips much more comfortable. You just have to make accomodations for it.
(I wish I could add some pics, but the picture icon on my screen is grayed out?)
