Power steering issue?
8.2K views 6 replies 5 participants last post by  anp1207
Having a weird problem this afternoon with my promaster. When it’s in park and I want to turn out of my spot. The steering wheel shakes and doesn’t want to budge except by force and there is a lot of squealing coming out of the front suspension. Power steering fluid is ok and no leaks. Anywhere I should start ?
Sounds like the bearing is shot on the top of one or both struts. You get a bit of noise the odd boing noise as well. Memory steer happens as well if the last direction you turned was left the van will pull that way when you let go of the steering wheel while vans in motion.
