Hi all!
I have a couple of questions, and I’m sorry if they seem basic—just trying to make sure I get everything right!
Inverter Chassis Grounding:
- I’ve read that grounding the inverter to the chassis isn’t strictly necessary but could be a good idea?
- I have a Renogy Pure Sine 2000W Inverter/Charger.
- Right now, the negative post from the inverter goes to a Blue Sea Safety Hub and then to the chassis ground. Is this enough?
- If not, where do I connect the ground wire on the inverter? I don’t see a dedicated ground terminal on it.
- I’ve run shore power into the inverter on the input side, but I’m unsure what to do next.
- Do I need to run anything from the output side since it feeds into the safety hub?
- Where do the wires (I have yet to install) go from here? Into a separate breaker box for AC?
- Or do I need to run the wire out at all since it is hooked up to the Blue Sea Safety Hub?
- I feel like I’m missing something simple!
