Help please! I bit off more than I could chew with my front end rebuild.
4.3K views 2 replies 2 participants last post by  moonfriedpotatoes
At the 8:17 point on the VC youtube video they are clearly use a large crescent to hold the top of the rear control arm nut and impact to loosen the bolt. I still think you need to remove the 3 bolts holding the bottom ball joint on the steering knuckle to reduce the space to get it back in position. After adding the spacer at the top off the strut it will be a bear to squeeze the control arm down for the extra clearance.
