Can I connect the positive wire for the B2B charger to this terminal?
The easier solution is to buy a mega fuse and install it like the one in the photo (post #8) with a couple of bolts. It will be simpler to do than trying to fit the circuit breaker in the battery compartment.View attachment 64884
Perfect, thanks for the pictures! I think I have it now. 🙏🏻I fused at the starter battery terminal with a mega fuse and also a breaker at the B2B end.
Same b2b, Sterling 30amp.
I like having the breaker on the unit end so I can disconnect the b2b for maintenance. And I like having the fuse at the starter batt terminal for peace of mind. Easy install and probably worth it as others have mentioned.
