Rare Three Passenger Campervan - 2019 3500 159" EXT - Fully built out
1 reading
Message
48 views 0 replies 1 participant last post by  Airstreamer
#1 ·
$67,000.00
Check price
Cary, North Carolina
For Sale: 2019 Ram ProMaster 3500 159” EXT
Mileage: 108,000 miles
Price: $67,000
RARE! True THREE passenger seating and sleeping!
Are you looking for a road-ready camper van suitable for three people? This 2019 Ram ProMaster 3500 159” EXT has been thoughtfully built out for comfort, functionality, and off-grid travel. With a spacious design this van is turn‑key and ready for your next adventure.
Swivel seats put it the van in lounge mode. There is also a fully functional kitchen featuring an 8.1 cu. ft. 12v refrigerator/freezer, 2000 watt inverter capable of powering an induction burner, hot plate, microwave, or toaster oven, 600 Ah of lithium batteries, 640 watts of solar to recharge, and operable windows, hatch, and vent to keep things cool. The van also features a professionally installed Webasto gasoline heater for those cold winter nights. Plus indoor and outdoor showers with hot and cold water! Full LED lighting, plenty of 120v and 12v power ports, and plenty of storage complete the build.
Photos and additional details below.
Interior & Comfort:
Professionally installed 3rd seat with DOT compliance
Two swivel captain’s chairs from Travois Vans
Sleeping Arrangements:
Upper bed: 60” x 72” (mattress not included)
Lower bed: 30” x 72” (mattress not included)
Sirocco II fan, LED reading lamp, and 12V USB charger at each bed location
Upper cabinets and three cubbies
Kitchen & Living:
Full kitchen with hot/cold water and plenty of counter space
Vitrifrigo Sea Classic DP2600iAC 12v refrigerator / freezer (8.1 cu. ft.)
Bosch ES2.5 hot water heater
Upper and lower cabinets.
Stand up interior 27" x 24" shower with hot and cold water and handheld sprayer
Outside shower with hot and cold water and handheld sprayer
LED lighting throughout
Insulation/Ventilation/Heating:
Havelock wool (walls & ceiling)
XPS rigid foam board (floor & walls)
Motion Windows T-Slider windows (side door + panel)
Maxxair 00-06200K roof fan (front)
Dometic Mini Heki roof vent (rear)
Professionally installed Webasto heater under passenger seat with mid-van mounted remote thermostat
Electrical & Solar System:
Two Q Cells 320W solar panels (640W total)
Victron Smart Solar MPPT 100V charge controller
2x300 Ah (600 Ah total) WattCycle Mini lithium batteries (brand new in 2025)
Xantrex Freedom XC 2000 watt inverter/charger with remote panel
Renogy 500A battery monitor
120V external charge port
120V external power port
Multiple interior 120v and 12v outlets
Plumbing & Tanks:
30-gallon Class A Customs T-3000 fresh water tank – interior mounted for freeze protection
15-gallon undermount grey tank, ICON HT706-ED with powered ball valve (from inside the van) for easy draining
SEAFLO 42 Series 12V 3.0 GPM 55PSI Continuous Duty Diaphragm Pump
SHURFLO 182-200 Pre-Pressurized Accumulator Tank
Misc:
Class III trailer hitch with 4-pin electrical wiring
The van itself is well-maintained and trouble free. The following maintenance has been performed.
Date
Mileage
Service
7/19/2019​
55​
vehicle delivery
5/12/2020​
3,117​
replacement van battery
7/28/2020​
3,663​
oil change
10/2/2020​
7,572​
oil change / tires rotated
11/13/2020​
12,147​
oil change
1/13/2021​
18,015​
oil change
3/30/2021​
25,269​
oil change
5/31/2021​
25,666​
air filter
8/24/2021​
30,429​
9/1/2021​
30,200​
brake fluid change
11/23/2021​
37,433​
oil change
12/25/2021​
42,098​
new tires
12/28/2021​
42,129​
oil change
12/28/2021​
42,129​
trailer hitch install
6/8/2022​
48,711​
oil change
7/12/2022​
50,999​
tire rotation
9/20/2022​
55,030​
oil change
2/9/2023​
61,319​
tire rotation
2/27/2023​
61,856​
oil change
3/20/2023​
63,137​
transmission oil change
6/16/2023​
68,268​
oil change
7/5/2023​
70,494​
tire rotation
7/26/2023​
72,508​
right front axle change (rubber boot ripped from road hazard)
10/11/2023​
74,252​
oil change
2/29/2024​
78,946​
tire rotation
3/14/2024​
80,188​
oil change
7/29/2024​
86,048​
oil change
12/112024​
90,744​
oil change
12/12/2024​
90,766​
tire rotation
2/26/2025​
94,800​
new tires
4/11/2025​
97,145​
oil change, brake fluid, spark plugs, pcv valve, coolant
7/22/2025​
101,795​
tire rotation
8/8/2025​
102,500​
single tire replaced (flat)
8/12/2025​
102,500​
rear sway bar links replaced (broken by me fixing the tire on the side of the road)
Save
You have insufficient privileges to reply here.
