DKSI gas heater
6K views 55 replies 9 participants last post by  NWPro23
I installed my PHP 2 kw gasoline heater on my Transit about two weeks ago. It's been running great so far. Used the program mode on a trip up the coast. Ran it 3 times overnight x 1 hr each. Worked great. This weekend I went up the local mountain and ran it at 5500-6000 ft at 28-30°F outside. I ran it continuously through the night at mid-setting. Ran perfect. The unit has auto altitude adjustment. The controller, although tiny, can display the air pressure in kPa. I had lower reading at elevation vs sea level. I assume this is how the unit adjusts fuel/air mixture. The installation was fairly easy, but I had to consult with DKSI on the tiny check valve that came with the unit. It had to be installed closest to the heater's fuel port.
