Hey folks,
I'm working on revamping the sound in my PM. At the leads, I was only getting 8.8W per channel as measured with a multimeter, which isn't powering my Polk DB6501 components the way I'd like.
I'm working on running the speaker wire back to an amp underneath the drives seat, and totally forgoing the factory wiring because I can't figure out/access where the crossovers/resistors are for the tweeters. Rather, I'll go from amp>crossover box>direct to speaker and eliminate questionable things.
I've figured out the tweeter wiring by removing the AC vent and running it down through there. However, I'm totally struggling on wiring the woofer in the door, through the rubber part of the door jam, and into the body. I can't figure to find an exit for those wires. Does anyone have any suggestions?
Thanks!
Thanks!
