Took a second look when my local dealer finally received a 136 low roof (the size I'd probably want but with windows). As far we know this won't be built. There is the driver side slider option with window but I really don't care about the door, just the window. I'd rather not have the extra claptrap.
This time I noticed the windows are just glued on top of the sheetmetal. There is apparently no recess stamped in for the glass. I'm guessing you could just cut the holes and install your own factory windows. I measured, and the glass from the standard slider would fit both middle and rear of the driver side perfectly. The only issue would be the passenger side rear where the track takes up the bottom couple inches. Don't know how much a replacement side window costs but this does increase my interest.
