OK, did "a" stress test of my window ac. Please use for "gee whiz" info only!
SETTING:
-started test at 1305L with van in full sun 103deg, 7% humidity; large windows in mid, and bunkhouse in rear. Only windshield had sunshade.
-no appreciable wall or roof insulation.
-AC set to 72 deg, ECO mode (irrelevant, as it ran continuousy). AC exposed to sun, aside from shade from baggage door.
ELECTRICAL:
-210ah LION Energy batteries, Victron 712 shunt
-solar input OFF, B2B OFF, no additional load
WHERE I SCREWED UP:
-I didn't set the 712 parameters properly (specific for LION batteries, tail current, floor, etc). Ha, and I did some elect work but forgot to synchronize and reset SOC.
FINDINGS AT CONCLUSION:
-ran AC for 2-1/2hrs before I quit because I was mad at myself about the 712 SOC settings.
-712 showed I used 126ah. Consistent with LION battery-top bms display of 60% life left. (Lion has 20, 40, 60, 80, 100% led display). Amps varied from 47 to 50A DC, compressor running.
-AC was pushing out 69deg air; lowered interior van temp from 112 to 95 running constantly; exterior temp rose to 106 by 1535L. Inside temp of side window 117, windshield (front of shade) 121, bare van skin 105, bare roof under solar panels 100.
-712 said battery temp rose from 95 to 111. Vicron 2k inverter surface temp rose from 101 to 111--but internal fan never kicked on.
[email protected]: removed my mesh cover off condenser for last 1/2hr: actual amps immediately dropped at least 0.7A, maybe a bit more. Interior temp dropped 2 deg in that 1/2hr period and it seemed that inside air flow was higher (don't understand that...). Anyway THANKS Chance! Cover removed!
CONCLUSION:
-I'm happy with it. No rattles driving. When operating, front plastic grill rattles--jammed a wad of tissue.
-with 210ah batteries, anticipate 4+hr continuous run; longer if/when it cycles, like at night.
-there's 12" of space below AC to a 4" mattress when AC is stowed. Obviously, head position is to van's right. Knees do hit. The diagonal members might get padded.
-Beauty of the slides is that I can yank the AC totally out during winter months.
-must insulate!
