Oh no! Not this again. The last time this came up, a heated debate resulted. >The Ram site doesn't exactly make it easy to find the exact difference...
If you were FCA the 4500 kit would be $1,000 and the -1,000 conversion kit (ie. to go from 2500 down to 1500) would save you $1,000.I am coming out with 4500 Super Duty conversion kits for all PM vans. They come with 3 emblems and 2 decals which by definition apparently make the existing parts on your van assume said power. Conversely you can buy my 1000 conversion kit and your van will become smaller, lighter, and get better mileage. Your choice, $30.
$30 to make my 1500 118" WB a heavy-duty model?I am coming out with 4500 Super Duty conversion kits for all PM vans. They come with 3 emblems and 2 decals which by definition apparently make the existing parts on your van assume said power. Conversely you can buy my 1000 conversion kit and your van will become smaller, lighter, and get better mileage. Your choice, $30.
Grab some of your favorite beverage and go to the link in post #3 ....Ok, so what is the difference?
Just different suspension?
If you looked up the thread mentioned earlier you would find that there may be a small difference in spring rates as the numbers for some are different though any spring can be a part for all chassis. The 3500 have a anti-sway bar on the rear an option offered after market for $175. Other than that it is badging. This has been discussed at length!Ok, so what is the difference?
Then you'll know... or maybe not?
There's a few varying views on this.
Cool, yeah well the info seems to vary. I just want to know the exact difference. It's not rocket science, nor debatable; just looking for the exact differences. Can't believe they don't make it clear on the their website.If you looked up the thread mentioned earlier you would find that there may be a small difference in spring rates as the numbers for some are different though any spring can be a part for all chassis. The 3500 have a anti-sway bar on the rear an option offered after market for $175. Other than that it is badging. This has been discussed at length!
I don't think so. Here is the spec sheet for Canada. I think the US van is the same:The 1500, 2500, and 3500 each have different transmission final drive ratios.
Hi RD,I don't think so. Here is the spec sheet for Canada. I think the US van is the same:
http://www.ramtruck.ca/en_dir/pdf/specifications/promaster.pdf
Someone else may have more data.
Ouch! I see the sheet but I have also seen a spec sheet with all of them the same.... Sorry for the confusion. I'll try to find the spec sheet that shows them all the same but in the meantime confusion reigns. We need help here.......Hi RD,
I'm confused -- your pdf show for the final drive ratio 1500 = 3.16, 2500 = 3.43 and 3500 = 3.86.
Seems like they are different between 1500, 2500 and 3500?
Can you find the post(s). I couldn't find any reference by search so I went with the spec sheet for 2015. Why FCA published the earlier spec sheet showing them as different is odd. The 2015 spec sheet could be incomplete? It is clear the gasser and diesel final drive ratios and transmission ratios are different as would be expected but I am thinking the 1500-3500 all have the same ratio once you select gas or diesel.Hang on a minute. I thought we determined in the previous thread that the 1500 had a unique final drive, but it was the same for the 2500/3500. I thought we determined this by getting tach readings from various owners.
