Has anyone measured all those holes? Does anyone know the exact sizes by mm or .001 inch? Need to know the diameters of the holes for purchasing nylon pushpins/clips.
When you say bottom ones are you referring to the kits?I just got my Rivet nuts. They fit perfectly!
The bottom ones are what I ordered:
http://www.mcmaster.com/#standard-rivet-nuts/=xrmfd7
I'd agree the standard hand squeezer won't work great. I'll probably use a bolt and impact gun.
These are listed as heavy duty rivnuts. Does anybody know if they are more difficult to install without a tool than would be the case for the standard rivnuts?Sorry, for some reason the correct web page didn't paste. Click on the heavy duty twist resistant ones and the bottom of that page Part # 90720A500 is what I ordered.
Thanks CCSorry, for some reason the correct web page didn't paste. Click on the heavy duty twist resistant ones and the bottom of that page Part # 90720A500 is what I ordered.
I could only find heavy duty ones in the hexagonal shape. I will probably go with standard rivnuts for my cabinets because the hex holes are only in the aft end. Not sure why they used so many different size/shape holes.These are listed as heavy duty rivnuts. Does anybody know if they are more difficult to install without a tool than would be the case for the standard rivnuts?
Italian vs German designers...Not sure why they used so many different size/shape holes.
