So the Ducato tray fits, did you have to modify if? any issues with exhaust heat?Full underbelly protection 😍
All the mounting positions are there and it's pretty crazy how well it fits considering the massive engine we get in the USA. While I was installing it I noticed that they kept the pans shaped a certain way that matches this underbelly pan setup nearly 100%. I just had to flatten part of the trans pan area and put a little notch in the naca duct part of the plastic pan where the exhaust is. (look carefully at the center of my pic for this)So the Ducato tray fits, did you have to modify if? any issues with exhaust heat?
Fits Fiat Ducato Peugeot Boxer Citroen Relay 250 Engine Under Tray Cover Shield | eBay
I tried to install one on my 2019 118WB a couple years ago and none of the holes lined up on the driver's side panel. Did you just order the middle panel or middle plus driver's side? Also, where did you get it?All the mounting positions are there and it's pretty crazy how well it fits considering the massive engine we get in the USA. While I was installing it I noticed that they kept the pans shaped a certain way that matches this underbelly pan setup nearly 100%. I just had to flatten part of the trans pan area and put a little notch in the naca duct part of the plastic pan where the exhaust is. (look carefully at the center of my pic for this)
Otherwise, no brainer. There are just three hex holes in the subframe that need rivnuts installed (I'm ordering from the dealer) and that's it. Otherwise it's all there. I got it shipped from the EU with a hardware kit for $200.
I ordered the three piece complete set.I tried to install one on my 2019 118WB a couple years ago and none of the holes lined up on the driver's side panel. Did you just order the middle panel or middle plus driver's side? Also, where did you get it?
Ok I got to ask, is it parked or are you driving it?Removed the plastic things the dealer botched on the rear door, replaced with stainless hardware and mounted our Italian license plate. 😊
View attachment 73423 View attachment 73424 View attachment 73425
If you look carefully, the US plate mounts over it, with the two screws at the top. 😉Ok I got to ask, is it parked or are you driving it?
about $80 for oil change hereI had my oil changed at the dealer. The only tank I have under is Propane . . . they did not mention it.
Also, what did your dealer charge for the oil change? Mine charged $52 including tax -- which I thought was very reasonable.
Nice ! That's barely more than buying the oil and filter myself.Check for coupons, we're getting Full Synthetic at dealer for 3 changes for $100 ($33/ea).
Mopar Coupons & Special Offers | Official Mopar® Site
