1 - 15 of 15 Posts
For those who have the Webasto Gasoline heater where did you order?
I'd be very thankful for a link/url.
When ordering are there other parts/pieces I would need?
I'd like to hand everything needed to the installer at one time.
He is doing an install now but placing the heater inside a cabinet directly behind the
driver's seat.
We would prefer the under passenger seat location and want to use the cabinet
behind driver's seat for all electrical items.
Thanks as always!!!
Administrator
I would say MsNomer has just finished covering this subject extensively in the past few weeks.
Discussion Starter · #4 ·
Yes I know MsNomer is doing a gas Webasto install and I thought I had read all her posts concerning but
I did not see links to order.
I'll keep reading.
I did read on another blog that the 2000STC is not covered by support in n.America that I need the 2000TC.
Any more info on that?
I'm just happy the bean-counter/the Mrs. is considering this in the primary build. I get cold, she gets hot :)
I used the spot behind the drivers seat and my build thread shows (with rulers) where it fits. There is a longitudinal box beam you have to be inboard of. Mine is a diesel but I believe they are the same size as the gas. As long as you have access to service it you can put it below a false floor that is only about 5” off the van’s floor so little room would be lost and perhaps the electrical could be housed on the back portion of the cabinet wall. OTOH electricity and gas don’t play well together so be cautious.
I'll keep reading.
Yes, I posted extensively about my search a few weeks ago. I am traveling stuck with poor signal and iPhone, so I will let you look for it.
Bottom line is that you buy from Europe with effectively no warranty or buy from an authorized US dealer. Melloronline was the cheapest I found online. For US, find the list of dealers on Webasto's site and simply start calling. If you ask, these guys will send you the page from their order book that details the kits. If I recall correctly, the US part number is 5010205A. This gets you the unit, fuel pump, wire harness, plate and gasket, associated hardware fittings. It has the rear inlet grill but no outlet grill and no ducting. Electric harness to the fuel pump is 17 inches. Because I particularly like the outlet grill offered, I am ordering outlet grill and ducting from esparparts.com. Ducting and grills are identical for Webasto and Espar – 60 mm. To save this hassle, there is an additional "RV installation kit" that can be ordered. It has ducting, front grill, fuel pump harness extension. Webasto tech sent me a fuel pump harness extension which he said can be spliced for extra length, he recommended not splicing into the original 17 inches.
Hey now... a Peterbuilt Store 90 minutes away from J.C. is a Peterbuilt Store 20 minutes away from me on Rutledge Pike, Knoxville. :D Did they price it fairly competitively?
Heater is down on the list of things for me to get. Guess I need to update my build thread.
Also interested in price because MSRP is $1358 but some have quotes of less than a grand.
Discussion Starter · #10 · (Edited)
Ted that is most likely the same one (Peterbuilt store)! For the kit #5010205A provided by MsNomer (thanks again) it was either a bit over 1100 or 1300, I think 1300 but I'm at work and can't remember :(
I can double check soon.
OK, just checked. $1148.
The heater is not a pressing issue for us either at this point, it will be warm by the time we get that far it looks like the Webasto is an easy (for someone who knows what they are doing) add on later in the fall.
But the installer in Asheville is putting in a Webasto into a Promaster even as I type so might be a good idea to get ours in as well when the process is fresh on his mind.
Now, he is also install in a place other than under the passenger seat.
I wonder what advantages of the differing placements???
MsNomer is going in front of the tire well and this installer is placing one in a cabinet behind the drivers seat.
Thoughts?
The fuel access port to the tank is under the floor close to the driver's seat. I figure a shorter fuel line routing is better. I will need to figure out a way to run a fuel line all the way to the spare tire area where my generator will go. For my setup I figure add a T into that line and mount it like RD did under the raised floor of my dinette behind the driver's seat since I will have a similar living space up front. A lot probably depends on your floor plan and if you will have water tanks under the floor towards the back. The exhaust runs down the driver side so the exhaust from the heater can share that space well.
Is your builder Morehead? He did Steves build and I liked what I've seen of his work so far. If he has a good method to mount and route it all, no need to change it. Do what works.
Not a bad price on the heater. We will be dinged for sales tax, but then won't have to pay shipping. Win some, loose some. Most of the truck shops around Knoxville are decent to deal with.
Edit:: where will your sleeping area be? I tend to sleep better where it's cool. Bed in the back, heat up front to keep toes warm when in the living area makes sense to me.
Discussion Starter · #12 ·
Ted we're doing a euro-industrial build.
Example, our final floor is the Legends KKS.
Nothing fancy at all=easy to clean pop in finished walls.
More simplicity-no water system except the Boss shower in the back.
We're going for a 'gear hauler' layout. Platform bed in back, higher than normal.
Under the platform bed a shelf, high enough to allow the Boss shower.
Under that shelf two Slidemasters, dual direction.
On the slidemaster driver's side toward the 'den' the ARB frig/freezer, behind it an Artic cooler.
On the slidemaster passenger's side toward the 'den' a potty (for us), behind it a potty (for the Maine ****).
Opening the back doors you would see on the slidemasters right and left Pelican cases (we're into photography),
above that the shower machine on the right, various oddities in the middle, and far left a sliding basket suspended
from the platform bed. The sliding basket (metal backet) slides into the 'den' where it has food prep items.
When in the den looking toward the back the sliders, the shelf-which from this side you'd see clothes totes/duffles.
Turn right 90 degrees and the only cabinet in the van. Floor to ceiling. Fold down table. I think there is 5 feet between
the bed and the drivers seat, so plenty of room for two people with laptops on the fold down table. Table also acts as food prep...we're like MsNomer-several thousand miles of backpacking and cooking to us is a small canister stove/boil water/let it sit 15min's then eat. Any 'real' cooking will be done outside. You know some people live to eat....not us.
Behind the fold down table=outlets for charging camera batteries, a little higher the microwave/TV-DVD/coffee pot (all DC, I'm just now discovering DC appliances Ha!). Above that maybe open shelves and cabinets running against the ceiling all the way to the back of the camper.
Under the folding table the electrical (charger-inverter/batteries/etc.)
Swivel seats up front.
A 'box' running side to side with hinged opening behind seats, box so your feet don't dangle when you swivel around. Maybe a pedestal table hole in the box.
Where's the sink? Haha! I think you get the idea of our build.
Now why the emphasis on the Pelicans, the slider, the laptops? I've linked to this here (I think) before, but for you Ted-
Mine- https://www.flickr.com/photos/medicineman4040/albums/72157639928047355
Poof's-https://www.flickr.com/photos/[email protected]
So really we're making a mobile photo platform where we can crash before driving to the next shoot.
Wow, great description for a photographer (mind picture)! You have more thought in this than most of us who ended up with about what we wanted. A note of caution. The van needs to take care of your living requirement with as little difficulty as possible, in wonderful weather with no bugs, vermin infested swamps, and frosty mountain camps. If your conversion can this do that you are good to go. Modifications will happen. Plan for them by having a way to run wires later. get access to the walls, floor and at least the ribs of the ceiling and walls. Attach stuff with threaded fasteners to allow that. You have a great plan.
Love the sound of the description. Can't wait for pictures! Y'all will be taking pictures, right?
I can spend some hours looking through both of the portfolio links. Thank you for sharing!
1 - 15 of 15 Posts
