1 - 4 of 4 Posts
How do I know which one is positive and which is ground for the wire coming out underneath by the air intake? There is no markings?
Sent from my SM-N986U1 using Tapatalk
I have no idea what the other end of the harness looks like, but;
If you have a multimeter & can access the other end, & you know the +/- on the other end, then a simple conductivity test can identify the unknown ends in your photo.
Can you pull back the covering to assess the colors of the wires?
You may find helpful info in the description of our gas Webasto install on my blog.
msnomersvan.wordpress.com
2019 3500 extended, white. Stella.
I believe you are holding the wires for the fuel pump which I don't think it matters.. + or -.
Check out the Blog on the heater thats at vanlifeoutfitters.com I found it very helpful. How To Install a Webasto Gasoline Heater In Camper Van
1 - 4 of 4 Posts
