I just installed my Webasto 2000 STC, and I am striking out on the altitude adjustment where I am to ground the brown wire coming from the #7 pin, set the rheostat to 12:00, etc. After a few failed attempts, I pulled out the wiring harness at the heater and have discovered what looks like the pin is missing from the #7 male connector on the control board at the heater.
I contacted Webasto's technical support and they said I would need to take it to a dealer and have it calibrated with their magical expensive machines. (They also said if I had the RV version and a Multicontrol I could set it to an altitude correction mode from the controller, but I don't have that altitude option on my Multicontrol so I don't think I got the RV model). So how would Webasto adjust the Co2 settings with this pin missing? What am I missing? Do they have a special harness they plug into the control board that makes contact lower?
I am very tempted to stick a paper clip/pin through the harness so that it makes contact with the board at the heater and ground it. The wiring diagram that came with the heater shows this pin going to a switch of some sort. Any Webasto experts out there?
