1 - 20 of 39 Posts
· Registered
Our first expedition of the year hasn’t started well. Southbound - - just north of Jackson, Mississippi - - we were on the phone confirming a campground reservation 20 miles south at Le Fleurs Bluff State Park - - when we were suddenly confronted with a rapid, repetitive banging/ratcheting noise. Our preliminary inspection revealed that we’d lost our engine!
Wheel Tire Sky Vehicle Land vehicle
Literally, but not completely. The driver’s side engine/transmission mount had failed and the engine was ‘dangling’ - - held in position by the passenger side mount, drive train, and who knows what else. The three lateral mounting bolts had sheared, leaving their broken studs visible in the engine/transmission housing while a fourth, a vertical bolt - - remained positioned upwardly above the engine/transmission - - having ripped free of, and damaging, the associated engine mount bracket.
Tire Wheel Automotive parking light Automotive tail & brake light Vehicle
Motor vehicle Automotive tire Automotive lighting Auto part Automotive exterior
The mechanic who worked on our problem handed us one of the removed, sheared studs . . . and we instinctively inquired: “How could this happen?”. The mechanic, redirecting his gaze toward us, asked: “Has anyone worked on this transmission?” “Yes,” we responded, “the transmission was replaced three years ago.” The mechanic smiled, “that’s your answer.”
We don’t know for certain what the shop did, three years ago, when they replaced the transmission. But our current mechanic believes he knows - - that shop reused the mounting bolts in the face of Dodge’s installation instructions which state in the most uncertain terms, at least three times, do not reuse. Here is the text of Dodge’s manual:
CAUTION
This CAUTION is related to the 2014 through 2020 model year VF ProMaster vehicles equipped with the 3.6L engine and 62TE transmission to emphasize the importance of REPLACING and TORQUING the ONE TIME USE fasteners that secure the LEFT transmission mount bracket to the transmission.
The fasteners used for the 2014 through 2020 model year VF ProMaster LEFT transmission mount bracket are of the single usage type and MUST not be reused. Once these fasteners have been torqued, they MUST be replaced upon removal. The torque of the fasteners are of a higher value than torques for a similar sized fastener. Verify all mounting bracket torque values, refer to . . . .
(Photos Omitted)
CAUTION: DO NOT reuse the transmission mount bracket bolts. Failure to use NEW bolts may result in bracket bolt failure.
Seven days later, we’re back on the road. And considerably lighter in the pocket book to the tune of $5,200. Why so much, we inquired of the Service Rep? “Well,” he responded, “ if you were an automobile, we would have charged you the “car rate”, but since you’re a truck, we charged you the commercial truck rate of $185/hour.” And then there were the parts . . . with the funny story that we consulted with our son, the mechanic, when this shop indicated they were having problems obtaining certain parts. So son Timothy obtained the critical bracket and bolts and overnighted them to us . . . it turns out that there was an error in the Dodge manual and this shop had ordered the wrong parts anyway. We’d still be sitting there but for our proactive intervention. Then there was that $1,300+ engine wiring harness . . . . did we need it? Timothy says “probably not” . . . but, then, we didn’t want to be sitting here another month, so not faulting the shop for ordering and installing it.
The Service Rep with whom we principally dealt was very sympathetic and helpful; the “mechanic” seemed very capable and knew his stuff . . . and, importantly and relevant to the issue we raised last summer of ‘getting help/service on-the-road when you need it’ . . . this shop immediately inspected our vehicle and got the parts “coming” . . . when all parts were “in hand”, they promptly turned their attention to our vehicle and got us out of there. Our only sadness was the dealership manager who - - when someone ‘ratted’ on us and revealed that we were sleeping in our van in their parking lot (while awaiting the parts), forbade this arrangement forcing us to incur another $70/night expense.
So, if you have this vintage ProMaster and have any transmission work performed . . . be forewarned.
· Registered
2022 PM 159 HT
That's a bummer but a lot of mechanics that don't work at a dealer (and some that do) never know these things. One time use bolts and clips are more common on vehicles now.
OEM's are trying hard to have their vehicles repaired only at their dealerships plus most have to be. At least for calibrations and ADAS scans, even from removing a mirror or bumper cover.
· Registered
The service seemed like they made you a priority but the commercial truck rate and camping fees seem like a "squeeze". I would think the original trans shop has some liability exposure. At the least they should be notified.
· Registered
I wonder what their car rate is? $185+ / hr is not at all out of line for any auto work in this area.
Interestingly enough, I charge people about 1/2 of that and they still complain - but will happily pay those rates at a repair shop..... Maybe I should raise my rates ?
· Registered
Mississippi is not California. Maybe a good plan would be that if anyone removes these bolts they have to give them to you.
Another (minor) consequence of this disaster was that it foiled the plan for Lola and me to meet up with Winston and VJ in New Orleans.
· Registered
Sorry to hear about this.
For the paranoid-minded among us that have had transmission work, could that bolt be easily removed and replaced with a new one without tearing everything apart? (Fwiw, my transmission work was done by a dealer, but since they botched the first iteration of the repair, let’s just say my level of faith in their skills is low.)
Edit to say that my dealer probably wasn’t as incompetent as I feared, as my paperwork has this paragraph:
---INSTALL TRANSMISSION. REPLACE ALL TRANSMISSION MOUNT BOLT PACKAGE SPECIFIED IN SERVICE INFO. REASSEMBLE VEHICLE
I stand by all the other things I’ve said about the dealer, but I was wrong on this one.
· Registered
Winston,
Sorry to hear of you troubles. It sounds like you were lucky enough to find a competent and professional place to get your trouble resolved. Would you mention their name? I'd like to know it in case we ever have trouble in their neighborhood.
Tom
· Super Moderator
2018 136" HR
Sorry this happen to you.
When I first read the engine fell off, I knew someone reuse those bolts. Pretty much all the posts of engine fell off the van are related to reusing those bolts and happens both in independent shops and dealers.
I also wonder how hard to replace those bolts yourself if they had any recent transmission work done and those bolts is not part of the invoice.
Hope you can recover the repair cost.
· Registered
2019 118" Silver
An engine hanging down in easy view always looks bad, good that there wasn't more damage. Glad it didn't cause a serious accident and they were able to get you back on the road pretty quickly.
· Premium Member
2021 3500 Extended
Yep, Winston ain't the first, nor will he be the last. If you can prove that the bolts were re-used, then file a small claims suit in court.
Btw, it sounds like you hit the lotto on finding a good mech to fix it.
· Registered
DIrt Rider: I don't think those are the bolts in question. Those bolts are on the passenger side.
The OP's photo shows the transmission cable and the driver's CV joint in the very lower left.
I think we are talking about bracket (7) and bolts (6), but this diagram shows qty 4, not qty 3 bolts.
It is hard to access the bolts, but I think they are marked "SFT 14" on the head. I don't know what that means.
From Steve White Automotive:
Mounting and Skid Plate for 2015 Ram ProMaster 1500 | Steve White Parts
1 - 20 of 39 Posts
