Hi All,
I have this freshwater tank I ordered a while back (see image). I'm baffled how to hook up fittings so I can fill and draw from it completely.
My question is on the placement of the fittings. Most tanks I see have fittings at the VERY top corners of the tank (second photo), and the tank is often molded with corner recesses (see last picture) so that the maximum amount of water can be filled/drawn from the tank.
On this one, the fittings are quite far from the top/bottom of the tank.
FILLING: I'd use the larger top fill hole, and the top vent. As long as the fill is vertically above the height of the tank, it should fill completely; correct?
DRAWING WATER: I would use the larger hole at the bottom. However, without any slope in the tank, won't an inch of water sit at the bottom of the tank? Plus, the opening is so large; once it got to 1/2" down the height of that fitting, I think the pump would start sucking air. I can use the smaller bottom fitting as the draw, but the same problem persists, and then I wouldn't have a drain.
Am I being silly or missing something? This tank seems robust and well built, and it's made by a reputable company. There must be a way to make this work WITHOUT adding additional fittings?
