Does anybody know if the two person section of the wagon rear seat can be removed leaving the single seat in place?
Use a 15mm metric socket to remove the 3 seat bolts. Remove the front 2 bolts first (in the slanted face of the floor).
Then, remove the vertical bolt, allowing the seat to move vertically as you loosen. When you replace the seat reverse
the order - put the vertical bolt in first. If you don't, the seat will not align with the front bolts and you'll bung up the bolts.
You have to keep the seat pushed toward the rear of the vehicle while putting the vertical bolts in so the front bolts
align to the holes. The outboard side of the double seat uses a pin for alignment, so only 3 bolts are needed. In my van,
I replaced the single seat with a cabinet for campwares. I often take out the double seat to house 2 coolers under the
front of my bed. I love the configurability of this van! I find a new way to use it every day. See pictures in the "classified"
section of the forum. Its labeled Promaster Classifieds, but we subs can use it, too. My add has a bunch of pictures.
Its the first Promaster City you come to, probably the first ad you come to, until someone adds another.
