Just wondering if you found out anything more about this? I am thinking of ordering one of these. ThxHi, I have a Vanrug in my 136. I just pulled it out and discovered water under it. Not just moisture but water just next to the driver side wheel well. And since it is sitting at an angle in the drive right now the water ran and there was a couple tablespoons or more of water that ended up behind the drivers seat.
A leak? It did storm last night. Condensation under the rug? I did sleep in it a couple nights ago.
I couldn't find anything out of the ordinary or anywhere that water may have infiltrated.
Anyone have thoughts?
Thank you, Nancy
I installed my VanRug a little while ago, but just got around to dealing with the two front panels. I removed them to install the rug. I was planning on trimming the panels, but decided to trim the rug instead. After putting the trim pieces back in place I was pleasantly surprised to discover a tiny "L" shaped cut already in the VanRug. This cut was exactly where the corner of the cutout needed to be to fit around the trim piece. I used scissors to make the cut.I need to trim the plastic interior panel up by the seat. The vanrug is taller than the clearance below the trim and floor, not much a belt sander will fix that easily.
Any particular reason why you went with the VanRug + Rubber mat vs. a VanTred?I just got a van rug....On top of it I put a rubber mat since I will be hauling dogs (in crates) in training that will get muddy etc...Expensive but now my floor is done...
