Folks
My questions about 136HT 1500 vs 2500 have been answered. With my light build, I'm going with the 1500.
Meanwhile my other question about dealing with the pronounced tilt received some informative replies, but for me the question is still open. Since the "Tilt" issue wasn't mentioned in the thread title, I started this thread to link to that thread.
Several of you wrote about simple fixes: tilting the bed mounts, front wheel elevation devices, looking for tilted parking spot, which will help compensate, but I'm looking for a robust solution that will address the cause.
RDinNMandAZ wrote:
"Some posters have removed a leaf from the springs and then added airbags but expect to pay $400-$500 depending if you have a compressor for them. KOV did that. I talked to a truck spring shop about de-cambering my rear springs and he can do it but suggested I camp for the winter and make sure I want it done. I have, I do. I'll post up in early June what the difference is."
$400-$500 is okay if it works well, but it sounds a little complicated. De-cambering sounds much simpler so I lean that way. I look forward to hearing RD's report.
Has anyone else worked on the issue? Anything to report?
Larry B in Portland
Planning my move from VW Westy to Promaster 136HT
Larry B in Portland
