After seventy-some years, I got bored and converted to a camper.
No previous experience including electrical, carpentry but I made.
Two 12V 100W solar panels parallel connected.
Two 12V 100Ah AGM parallel connected.
Even on 800W use, the Inverter cut off after a few minutes.
Try to connect Isolator to complement while using a hot plate.
Wanderer has no connect point.
Recently found the cable is not big enough, some say need 2G or 1G.
Any advice is appreciated.
(2022-05-07) Thanks everybody.
After advise, changed 4G wire to 2G with 125A fuse.
Also main fuse box 10G wire have 20A fuse.
Still not enough to operate 1200W induction cook top.
Will check all voltage level. And put the result next week. (out of town)
