I was going to suggest the hardware store, too.Can you remove one of the other bolt that is still on there and try to match it up at a hardware store? Most of us don't have that belly pan, assuming Travato custom made for their van.
Good idea and yes, that's possible but preferred to avoid that if someone had the info AND there's the possibility that the one I need is not the same as the others (aka "just my luck")Can you remove one of the other bolt that is still on there and try to match it up at a hardware store? Most of us don't have that belly pan, assuming Travato custom made for their van.
Thanks. It's possible Screw (6107017AA) and nut (6106406AA) combo may be the right solution. However, it appeared the hole is threaded which would make that combo, potentially wrong. I'll crawl back under this afternoon to take another look.
