Hello again. It's been a while since I posted but I'm having a problem with my van. The service transmission light came on while I was driving the other day, then went off but the check engine light stayed on. I took it to my mechanic to get the code read and cleared. It was p0613.
I googled it and apparently it is a fairly generic transmission code which means (a) bad TCM (b) faulty wiring (c) faulty sensors. My truck is still under warranty.
Today it threw a code again and kept flashing until at one intersection it shifted to neutral and would not engage a gear. I restarted the truck and it worked fine but still had the check engine light on.
At the end of the day when I left to go home the check engine light was off. I'm wondering if anyone else has had an issue like this and could help me out. I imagine this means it needs to go to the dealer but was wondering if there is something I should look into before sending it in.
