Has anyone used the PM to tow a car trailer? I had a hitch installed yesterday and was told that I wouldn't need a power brake set up. What do you guys think? (13 foot trailer for Fiat 500.)
Is it possible the trailer has surge brakes already? If so you shouldn't need an electric brake setup (if that's what you mean by "power brake set up").Has anyone used the PM to tow a car trailer? I had a hitch installed yesterday and was told that I wouldn't need a power brake set up. What do you guys think? (13 foot trailer for Fiat 500.)
All trailers I've pulled that had surge brakes only had a 4 prong connector. If your trailer has surge brakes built-in already, it will have what is essentially a brake master cylinder at the end of the tongue where the ball coupler is.The trailer I'm going to pull with my new PM 2500 is a SCCA 2 axle 13 foot club trailer , it has a 4 prong connector, I've pulled car trailers before with my Ram truck but it had electric brakes with a 7 pin connector.
I have a 2014 136 lowroof. I towed 2 hours each way good mix of hills and flats,60-65 mph . Prolly 850lb in the van. Filled up when I left and did the calculations when I filled up again 13.4 MPG. My Van has less than 500 miles on it.Troffer,
Can you give more details about your experiences towing? How far do you tow? What size pm do you own? What kind of mpg are you seeing? At what speeds? How much weight do you have in your pm when you tow?
I'm very curious. Thanks.
That's excellent mileage for that heavy a trailer; granted it's low profile and tucks nicely behind van, but excellent nonetheless. Have you gotten MPG estimate driving without trailer?I have a 2014 136 lowroof. I towed 2 hours each way good mix of hills and flats,60-65 mph . Prolly 850lb in the van. Filled up when I left and did the calculations when I filled up again 13.4 MPG. My Van has less than 500 miles on it.
