1 - 12 of 12 Posts
I have been using Tow/Haul Mode for a week. I was getting 14.6 mpg now getting 15.7 mpg. When going up hills don't have to give as much gas to get it to downshift. The shifting sequence seems to be a little different.I think I will be using this mode all the time. I will just have to remember to push button every time I start. This seems to be good for me because of the weight I carry.
That doesn't surprise me. My ram 1500 actually gets better mileage if I keep it in 5th gear manually. I just have to remember to hit the button and often times forget. I think in 6th gear it lugs too much. I actually don't like the tranny on my 1500, but it works.
It surprises me not many folks have thought of this. Simple and easy, no harm done gas mileage tweek. It works like a charm
Reactions: antmanv1
Other than the shift sequence, what else does using tow/haul mode do? Will it always give you better gas mileage or does it really only help when you have a heavy load in your Promaster?
It keeps the transmission from over working and generating too much heat when pulling heavy loads. Translation..............burnt transmission fluid.
It also down shifts sooner for any given speed, so it aids in engine braking on hills.
It also in these new computer controlled, drive by wire engines, keeps the engine in a favorable rpm with a bit less throttle opening for a given speed compared to the non tow/haul mode
My Promaster 3500 based Dynamax REV 24RB RV on level Interstate 10 in Florida 70 mph cruise gets 14 mpg in 6th, 12 mpg in 5th, 10 mpg in 4th; Instant. In D I average 12.5 mpg because it continually downshifts to 5th. When I tried TowHaul it seemed to stay in lower gear but I haven't tried it enough to get average mpg. When I drive close behind 18 wheel (not safe) or beside him with my rear even with his I get 16 mpg.
Try "Manual Mode"
I haven't messed much with the Tow/Haul function. However, I do use the manual shift mode a lot.
I used this while driving in the snow and ice it worked great. And I use it in dry conditions as well. shifting up and down as needed at times. A computer / auto transmission can not analyze terrain and load requirements as well as a person.
Not yet anyway;)
I have a Coachmen Nova Class B RV built on the Promaster 3500 chassis. Average 15.7 mpg +/-. Going to try Tow/Haul to see what impact it has because the RV weighs 9600 lbs.
I wish it was on and stayed on. I keep forgetting to press the button.
Reactions: antmanv1
All newly registered members MUST make an introductory post in the Introductory Post Forum as per forum rules. "Promasterforum.com Introduction Section " Please be aware until you do make the required introductory post any posts you make may be deleted.
haha, me too. i even tried a post it note once, but that didn't work. I've been getting to about 50% remembering currently. I thought of this subject while reading the manual for an older GMC van where they recommended using it all the time because it helped the transmission to run cooler. But, if it was downshifting on the flat, long hi-way, I would turn it off. You want to use overdrive (6th) when possible.
1 - 12 of 12 Posts
