1 - 20 of 70 Posts
We have been loving our converted Promaster for the last couple of years and have felt no need for a toilet. I am fine with a gatorade bottle and my wife a plastic ice cream container. A shovel and plastic bag for paper or the occasional gas station has been fine for #2. But, in the age of covid and a little more urban boondocking we have been thinking about a cassette toilet (the Thetfords look pretty good and one would fit perfectly under our bench seat). But I keep reading that no one likes to use them for #2 (we would want to ONLY use it for #2). What is the deal with this? Stinky? Difficult to empty? Are there better options? We don't want to have a fixed location, vented, composting one as we will probably leave any toilet at home during most trips.
2016 3500 ext-ht
Depends and wet wipes are easier. We bought an Airhead after dealing with a Thetford. And had a spin fitting put on the pee tank and under mounted gray tank. Done with that portable crap.🙄
But I still poo in the forest every chance I get just to piss the bears off. Crouch and scoot thru the leaves like a dog on white carpet. Too cheap for single ply.
I have a Nature's Head composting toilet and have set it up to be easily removable. There's a plug on the fan and I used silicone slide-on flexible hoses for the vent and intake. It takes just minutes. The bonus is that once you remove the urine container it's quite manageable and there's no liquids to worry about.
We use a C-head brand toilet and have been pleased with it. For just #2 you could use the same concept in your own bucket. Just some wood chips and a mixer. We don't vent and haven't had smell or moisture issues for the occasional use.
It was a bit expensive, and took some imagination to install, but we just completed our maiden voyage and it was very nice to poop and pee inside without odor, or any need to handle any waste or black water:
Use discount code JC202 for an additional free package of liners.
I hope to do a full write up of our install of the TinyJohn one of these days. In the meantime, feel free to PM me if you have any questions.
Wow! I thought my toilet was expensive...
2016 3500 ext-ht
Could you elaborate on the flexible silicone slide-on hoses?
To prevent back drafting issues (Mainly from the Maxxair fans) I set mine up with an outside air source so it has two hoses. The hoses don't have any hose clamps on them, instead I found some silicone ends that were the right size to slide over the hoses. I can get some pictures tomorrow and post them here, but it basically all comes out without any tools.
Do dry toilets really need the vent fan? I've seen a few brands without the fan and the claim is that you don't need a fan.
Check out the Laveo by Dry-Flush -
My Thedford Curve works great no matter what you "dump" in it. The prices seem to be all over the place now tho ($150 - $300)! Supply & demand plus a new name. I paid $120 for mine in’17 but those days are long gone😩
At least in the case of the Nature's Head, IMO if you actually use it regularly and as intended then they do need the fan. The fan not only pulls out offensive odors, but its overlooked function is to dry out the contents of the solids bin. If the fan is not working they can get too wet and smell or even mold, they fill up far more quickly and can even develop bug issues. Used correctly with the fan running I can get nearly a month of full time use out of mine before I have to change the substrate.
2020 promasrer 136 HR
We were thinking of installing a composting toilet under our bed area (in garage) that we could slide out to use, and stow away when not needed. We would vent thru the floor (I like your idea of two vents, one intake, one outlet) with a fan. The toilet would be built like GaryB, a sealed "bench" that would serve as a step up to our bed at night. Do you think it would be possible to have the hoses long enough to be able to leave attached - say four feet. Would that allow enough air flow to keep the system working?
Thanks!
You can build a very serviceable composting toilet for about $80 including a commercial urine separator.
The details on ours here: Our ProMaster Camper Van Conversion — Composting Toilet – Build A Green RV
It has worked really well for the 6 years we have used it. One of the best decisions we made on our conversion. No odor, trivial to empty, long time between emptying, no water supply, no freeze issues, customize to the space you have and integrate a magazine holder :)
Here is another kit for a composting toilet that Dennis found:
KOV, why would you want such a simple, elegant, home toilet-height solution?
It seems like it would be more fun to set up fans, get sawdust, connect hoses, spend lots more, or scoot thru the woods! 😈
The Curve... put in water, add batteries once a year, and GO (literally)
Thanks!
My hoses are over 6ft long as they are routed through to the rear and exit the floor behind the wheel well. So I don't see why you could not set it up that way.
Here's a few pics of how I enclosed the head. The plug is aftermarket, not the one that comes on the Nature's head and only one of the two hoses is easily visible in the pic, the other is grey and exits in the upper left corner. The silicone rubber ends were a bit longer and were cut down to fit.
67817
67818
We have the Thetford 345, we try to avoid #2 but with covid precautions that isn't always possible. The issue with #2 is some smell escapes every time you flush it afterwards, and obviously draining it becomes smelly. No other issues, though. We like how small and portable it is.
Pretty good video on the details of living with and using a cassette toilet
And similar for composting toilet:
1 - 20 of 70 Posts
