Hi Folks -
This thread to document the conversion I've started of a 2017 PMC Tradesman. The idea is to install a semi-permanent (but still removeable) floor, on top of which a 4' x 5' camper box unit that will slide out of the van when I need to haul large stuff.
The camper box will have hinged "wings" that fold out on top of the wheel wells, and a wing that will fold out forward toward the seats, creating a queen bed sized sleeping area.
Just getting started:
First installed the rails and bars available from the UK on ebay. Cheap and easy. Then purchased an 18 cubic foot (smallest I could with my needs) cargo box. I need this for my work, and for extra space if family camping.
I pulled out the plastic trim bits on the cargo floor and have sprayed on two coats of Lizardskin acoustic insulation.
Spraying inside the van has been a pain in the butt and the product was not cheap. I hope this effort was worth it. (I also plan to spray the ceiling, since I have enough product.)
I peeled the back door panels off and inserted thinsulate and have also begun stuffing thinsulate into nooks and crannies on the walls, in some case two layers. Broke several of the plastic pins. I have a dozen on order as replacements.
Not sure how I am going to deal with the former windows yet. They need some sort of insulation but I am trying to keep this job simple, and will not be aiming to have fully finished surfaces all around. After all, the whole camper unit is intended to be removable.
My house power will be supplied by a Zerogoal Yeti 1000. This has arrived, along with a Dometic CFX 40 liter fridge. The fridge will go on a rail inside the box, opening out the back door. The height of the fridge basically has determined the height of my bed platform / box top.
For farts and giggles, I half loaded the fridge with pre-cooled items and hooked it up to the Yeti. In the (77 degree) climate control inside my house, it burned through 9% of the Yeti battery in 24 hours. That's a hair under 7.5 12v amp/hours out of the 83 the battery holds.
In the real world, I expect the fridge (which draws 40-50 watts on 12v when the compressor is running) will burn through more like 12-15 amp/hours a day. My goal is 3 days of autonomy (no motor) and it looks like the Yeti will power the fridge and electronics that long. Longer if I supplement with a solar panel and/or charge the Yeti off the motor. Fridge will be powered by the motor when it is on.
Tomorrow:
Spray Lizardskin ceramic (heat) insulation on the floor.
Build the floor: Yoga mat, polyiso, and plywood.
Tomorrow:
